Shifting problem~
Old Jan 13, 2003 | 11:18 PM
Shifting problem~
I sometimes have problem on shifting from 1st to 2nd~
I don't know if it's my problem or what. It always not smooth enough compare to shifting from 2nd to 3rd. Also when I try to shift in R, sometimes it's hard to shift in and having some "chruch" sound.
So it's it normal or what???
Mine is a 93 R1.
thx
Old Jan 13, 2003 | 11:38 PM
Crashunit's Avatar
MIA
sounds like your syncros are going out..... wierd that your having problems from 1st to 2nd and not 2nd to 3rd. Are you having problems with 5th as well as Reverse? Those are the first two gears to usually go, when your syncros wear out....
Old Jan 14, 2003 | 01:40 AM
oo
i have no problem with 5th gear
it shifts smoothly~~
Old Jan 14, 2003 | 09:17 AM
Mahjik's Avatar
Mr. Links
When was the last time you had all the fluids in the car changed out?
Old Jan 14, 2003 | 09:38 AM
RonKMiller's Avatar
Blow up or win
Worn engine mounts.
An engine torque brace would eliminate the problem, don't use a rigid one unless you are pumping out big horsepower. I have a solution available. PM me for a picture.
Old Jan 14, 2003 | 09:43 AM
rjester's Avatar
I'm having a similar problem with 1st to 2nd shifts. I can't hear it grind, but I can feel it not wanting to go into 2nd. It goes away after driving for about 5-10 minutes.
Old Jan 14, 2003 | 12:47 PM
i just bought my FD
so i have no idea when was the last transimmsion oil change
Old Jan 14, 2003 | 02:43 PM
poss's Avatar
Slower Traffic Keep Right
if it grinds when the car is cold and not when it is warmed up, that is very common
Whether it is normal or ok is a different story.
Old Jan 15, 2003 | 08:05 PM
ok
2nd gear is rough
and reverse grinds sometimes
and car has been warmed up
what's the problem???
risingsunroof82
22
Sep 22, 2015 01:20 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
REX7&Z32TT
Sep 14, 2015 08:46 AM
