Air in radiator
Old Aug 11, 2001 | 09:44 PM
RICKRX7's Avatar
First change the radiator cap.If problem persists, have the coolant checked for exhaust fumes.
Old Aug 11, 2001 | 11:55 PM
HAILERS's Avatar
HAILERS
Rickrx7 is right. My understanding of how the thing should work is.......The radiator is full and the water in the overflow tank is on its hash mark. You drive the car and the coolant expands and the displaced water goes into the overflow tank. You put the car up for the nite. The engine and coolant cool off and cause a vaccum which pulls the coolant that went into the overflow tank earlier to now flow back into the engine. What could be happening with your car is the radiator cap is defective or the hose between the overflow tank and filler is defective which means instead of sucking coolant back into the engine from the overflow tank, it is sucking air back into the engine. Make sure the cap is good and the hose between the filler and the overflow tank are secure. Or your problem could be something else(don't think so) which we will not discuss since its Sunday and I'm trying to be a nice person for 24 hrs.Difficult to do.
