Need help with a project car...turbo convertible...
Old Aug 11, 2001 | 01:13 AM
ribs's Avatar
Whats up guys? I'm new to this forum...where to start....
I've had 2 RX-7's before (81 GSL-SE w/ 89 n/a engine and an 88 TII), so I know a bit about these cars, but was thinking of doing a project car, and wanted to start to gather data before delving into this thing head first.
I have just gotten into doing my own wrenching recently (I couldn't afford my 86' 944 turbo otherwise), and am getting ready to sell my 90' celica all-trac to free up some funds and car storage space...but I will never get rid of the porsche...I want to be buried in it....
My idea for the project: 87-91 rx-7 turbo cab...errr...convertible (no porsche talk here ). I would want to find a convertible in fair condition with a blown motor for cheap, and then find a suitable donor engine to go into it.
Now the questions...
Is there any difference between the 2nd gen turbo motor and 3rd gen turbo motor internally (by which I mean port sizing, port positioning, materials used for the rotors and rotor housings, apex seals, compression ratio, etc...I know that the induction system is completely different (simple single turbo vs. complicated as hell sequential twin turbo) and the FD engine obviously has more fuel coming into it, but internally) and could the 2nd gen turbo motor take as much abuse as the 3rd gen (i.e. lots of boost and CFM of air) if you had the fuel to match?
Does the n/a FC motor have a higher compression ratio than the turbo II motor? How is this accomplished with a rotary engine? It looks like you would have to change the geometry of the rotor (i.e. curve on the side) to increase compression ratio, but I am still trying to learn this stuff.
If I were to do this project, I would probably want to rebuild the motor before I dropped it into the convertible body. I have been told that the rotor housings on rotary engines have some sort of polished nickel/chrome plating on them that wears off with time, leading to blow by, compression loss, accelerated apex seal wear, etc...can this plating (if it does in fact exist) be re-applied? How expensive would it be to get done?
What is involved with installing 3mm apex seals in the rotors? How much more bullet proof would this make the engine? What is the pricing for 3mm apex seals?
Why are the turbos prohibitively expensive for 2nd gen rx-7's? I was looking to replace the turbo on my old TII with something "juicier", but the cheapest aftermarket turbos I found for the car were over $2000...I can get a nice T04E hybrid turbo for my porsche for less than $1000, and add $300 for ball bearings...how hard would it be to fit a turbo like that up to the stock turbo plumbing?
What kind of air metering does the FC turbo and FD engine use? I am guessing vein/AFM for the FC and MAF for the FD...anyone know?
That is enough questions for now...my fingers are getting tired from typing...I am sure I will think of some stuff later. Thanks in advance for your replies.
Here's my car:
Old Aug 11, 2001 | 08:42 PM
Evil Aviator's Avatar
Rotorhead
I honestly don't think that this is a good project for you if you are asking those types of questions, and are on that kind of budget.
Check with Rob500 - he just finished a low-budget TII convertible project, although I think that the AT drivetrain was a really bad idea.
https://www.rx7club.com/vforums/show...&threadid=7565
Old Aug 12, 2001 | 02:16 PM
ribs's Avatar
Which questions were bad? Budget shouldn't be a problem once I sell the all trac...I just don't know how far I wanted to go with this, and was trying to get a feel for what point would be good to shoot for. I just wanted something to occupy my time, and this seems like it could be a good way to do it. Thats all.
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
