blown tein's ????
Old Jan 8, 2003 | 10:57 PM
astrochild7's Avatar
controlled kaos
blown tein's ????
I blew the my tein's in the front does anyone kown where you can get rebuild kits. Or do you have to send them in to the factory.....
Old Jan 8, 2003 | 11:50 PM
EviLPeNeviL's Avatar
Can't live without boost.
How'd u manage to blow it?
I'm in the market for a new set of HAs and I have to know problems like these.
Thanks.
-Dan
Old Jan 9, 2003 | 12:48 AM
controlled kaos
just heavy usage love the susp..
Old Jan 9, 2003 | 03:31 AM
ARD T2's Avatar
which model?
Dan, go for monotube. And give me a shout. Someone mentioned for me to contact you. Can't remember who. Said you might need some help. I'm here for ya and you must be close by.
Later, Rishie
You should call Tein or the dealer you purchased them from. Don't believe rebuild kits are available. You might be able to purchase a damper itself and swap them out.
What model do you have?
Old Jan 9, 2003 | 10:56 AM
the_glass_man's Avatar
Will u do me a kindness?
TEIN USA can do them for you, go to their webpage and contact them.
Old Jan 9, 2003 | 11:11 AM
Tein USA will rebuild them for you. My rears blew out after less than a year. I sent them too Tein, and they said there were tool marks on the shafts that caused them to fail Anyway, I had to have them back, so I had them rebuilt. The cost was around 200.00 including new shafts. About a month later one of my front pillowball mounts failed(fell apart). I just removed the pillowball mounts all the way around and replaced them with the stock mounts(much quieter). This was on my 97 SupraTT. I have ground control/koni yellows now on my FC, I will eventually replace them with the GC Advanced design double adjustables. Hope this is informative, Carl Byck
Old Jan 9, 2003 | 11:42 AM
Originally posted by ARD T2
which model?
Later, Rishie
Rishie, this is Dan, I came in with Justin (green 5th gen Lude) a long time ago with my red Lude because I needed the rear tires swapped out for different ones, still remember that? Well I sold the Lude and bought a base RX-7.
Anyways I talked to Justin online and he says that you may have some FLT-A2s at a better price, maybe even the HAs as well. THat's what he was probably talking about.
It seems like under more spirited driving the TEINS will blow? If so then I might as well as go with the ever so popular Yellow/GC...........??
-Dan
Old Jan 10, 2003 | 12:46 PM
Mazderati's Avatar
I'm not sure about which models you guys are using/looking into but for what it is worth the RA and RE set-ups are for track only per Tein USA.
I was looking into a set of these for my car, which is driven on the street, not very much, but still is nonetheless, and the guy I talked to at Tein said that the coil-over RA and RE systems can not take the abuse of the street. He said that the dampers are made as light as possible and that parts can and will literally break. I would imagine blowing damper seals could result as well.
Good luck.
Kyle
Old Jan 10, 2003 | 03:42 PM
Mine are HAs, no excuse for a 1500.00 street set up IMHO. Also the HAs are NOT light. Carl
