first-gen stereo swap
Old Aug 10, 2001 | 04:53 PM
bylinepjw's Avatar
I'm trying to swap a new Blaupunkt CD receiver for the original stack of tuner/cassette/equalizer. I need a kit to replace all that stuff. Anyone know of a source?
Old Aug 10, 2001 | 05:28 PM
Max7's Avatar
Admitted Sevenaholic
I know there are kits for the 84-85's not sure of the others.
check any local shop, they should be able to get it for you.
Metra and Scosche make them.
Old Aug 11, 2001 | 03:06 PM
bylinepjw's Avatar
need antenna now
Ok, got the Blaupunkt in, but now I need an answer for the goofy Mazda stock electric antenna. Anyone found a replacement?
Old Aug 11, 2001 | 03:42 PM
Jason Guthrie's Avatar
Depends on what you had in mind.
1. Original antenna with new stereo
-----Get a negative triggered relay $8-20
2. New antenna assembly with new stereo
-----Just about any aftermarket antenna assembly will work $30+
I got my replacement from goodguys or circuit city. It was around $34 and I had to buy the negative trigger relay from a local stereo shop which I believe was $15. The install was very easy. The trigger simply plugs into exisiting wiring for the antenna I bought with an extra wire(signal) going to the headunit. Installing the actual antenna was one odd shaped nut located on the outside of the car where the base goes into the car and then there was 1-3 screws inside that stabilize the whole thing.
betes
Sep 27, 2015 08:25 AM
newtgomez
Sep 13, 2015 07:39 PM
