Rebuild Time?? I hope not
Old Jan 2, 2003 | 04:03 PM
AggieDave's Avatar
Series 5- T2 Motor. T04r Turbo, lots of goodies. Anyways here is the deal.
My Egt's seem to be higher than i remember them being. i ran a little lean, but i think that the motor is ok. i was not running more than 10-12psi. I have 550 prims and 680cc secs.
The car also will not idle smoothly at 800 or 750 rpm.. although it seems to run fine at 1500. I did a compression test on the rear rotor. removed the shraider valve and watched it jump. bounced around 90ish.. (cheap compression tester.) took the leading plugs out and listened for the clack or the inconsistant compression... sounded fine. what could be my problem??
Dave
Old Jan 4, 2003 | 11:02 AM
Ridge Tech's Avatar
vacume leak?
Th0m4s
Feb 26, 2019 02:04 AM
Leeroy_25
Aug 17, 2015 12:53 PM
