Guage Install- Help.
Old Dec 17, 2002 | 11:56 PM
OK, i got my new Grey Guages today... I got the Voltage/Oil & Temp/Gas guages installed with no problems. Now, how do you get the Tach and Speedo guages in place?? Is there some sort of trick to it? Thanks all- Rotary-Rex
Old Dec 18, 2002 | 12:12 AM
ioTus's Avatar
'84 5-letter
Slide the center hole over the needle, it will go straight on over the center thing.
for the speedo, you have to get it as far in as you can, and then do some contortionism to get it over the trip counter reset thingie.
Good luck, you'll be happy when its done.
Old Dec 18, 2002 | 10:42 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
You can use a screwdriver (small flat head) and pry the needles off as they are press fitted. Just don't go balistic on the needle, be gentle and work it off the shaft (a little bit on each side)
Oh man, did that sound sexual.
Old Dec 19, 2002 | 10:25 PM
ok i got the faces on,... now where is the positive and ground wire that you need to wire the guages to? Thnx -Rotary-Rex
Smokeyfb33
Old School and Other Rotary
Oct 1, 2015 12:10 PM
pfsantos
Sep 30, 2015 01:29 PM
