teflon water seals
Old Dec 17, 2002 | 07:46 PM
rx7will's Avatar
teflon water seals
has anyon have any experience with these teflon o rings for the water jacked on the fd. I called atkins rotary and asked how much they were because i thought they sold it, he said that he never sold it and never will. He said that they dont work and that pettit tried them they no longer use them either. First hand experience would be nice. Is hylomar the best thing we can do for the stock seals? I'm planning on doing a rebuild and was think about giving it a try.
Old Dec 17, 2002 | 09:27 PM
RonKMiller's Avatar
Blow up or win
Although there are two different kinds of Teflon encapsulated O rings available, I would stay with stock, and focus attention on carefull clearancing of ALL parts.
I am pretty sure most of the major rebuilders use OEM only for the water jackets. In your area I would check with Pineapple for Rob's advice, he seems to have an EXCELLENT reputation - far better than Atkins.
I think some of the airplane guys have used them, and in principal it seems like they would work really great.
From what I have read it would seem like they are truly superior to most materials.
Check out www.rotaryaviation.com. They do specify Teflon O rings for some areas. Their prices are absolutely the best on rebuild kits.
Hylomar is a brushable sealant used between precision machined surfaces, it's kind of like a putty when it cures.
Old Dec 17, 2002 | 09:37 PM
Carlos Iglesias's Avatar
Corn-to-Noise Converter
Veteran: Navy
Top Answer: 1
Used 'em.
Reused 'em.
Used 'em some more.
As for Cam's comment, that not what he told me last time I was hangin in the shop.
Flyin, Racin, and Buildin Rotary Beasts,
Carlos A. Iglesias
'93 RX-7 R-1 (Buildin')
'93 RX-7 R-1 (Sellin')
'95 M3 Sport (Drivin')
'01 Pathfinder SE (Towin')
http://www.the-rotary.net
Old Dec 24, 2002 | 08:17 AM
TailHappy's Avatar
Addicted to Track
Bryan at Rotorsports Racing likes them and puts them in his engines and he's been racing RX-7's for many years now. Plus, it's hard to imagine that anything could be WORSE than the stockers. They've caused a lot of trouble over the years!
They're in my new engine and so far, so good.
Old Dec 24, 2002 | 05:11 PM
rx7will's Avatar
The weird thing about the teflon seals from rotaryaviation.com is that i emaild them and they told me the inner water jacket seal is factory mazda part. I replied to ask if she meant the outter seal but she hasnt gotten back to me yet. Is that the only place that makes them?
Old Dec 26, 2002 | 09:12 PM
r0t0rhead's Avatar
The outer water seals are factory parts- as for the teflon/silicon seals-we've built an average of 63 engines per year over the last 4 years, all with silicon/teflon seals-no failures yet. In fact our own racecars' engine had the engine torn down for inspection and the seals were re-used just to see if they would leak-they didn't.
We also use them in the Diasio 962R bridgeported race engines.
Bryan Smith
Rotorsports Racing
Old Dec 27, 2002 | 01:33 AM
rx7will's Avatar
I'm pretty sure she meant the outer seal is stock and the inner one is teflon/silicon, but she hasnt responded. Any one know for sure how many different kinds of teflon inner water seals are out there? Which ones do you use r0t0rhead? Are there one one brand?
Old Feb 16, 2009 | 07:03 PM
fastassturbo2's Avatar
risen from the dead...any news.....on if there good or bad???
Old Feb 16, 2009 | 07:09 PM
IRPerformance's Avatar
Sponsor
If a customer requests upgraded water seals I use the ones from Pineapple. I have had issues with the other brand not fitting correctly.
Old Feb 16, 2009 | 07:48 PM
arghx's Avatar
rotorhead
I just went through this whole teflon coolant seal deal when building my motor.
First of all, from what I can see, the outer coolant seals from Rotary Aviation are NOT oem parts in the sense that they are not straight from Mazda, although they may be made of similar material. How do I know? They do not have white paint on the side like the factory ones do. I have compared the two side-by-side.
I have also found that the McMaster-Carr teflon inner coolant seals fit the best out of the teflon ones available (part # 9319 K239 on the McMaster-Carr website). They require zero stretching with basically OEM fitment and are ~6% thicker than the RA ones based on measurements I have taken. I have not used the Pineapple ones but Pineapple tells you to stretch them out to fit, something you do not have to do with the OEM inner seals or the McMaster-Carr teflon inner seals.
Old Feb 17, 2009 | 02:00 AM
FutileLover's Avatar
Project FD
i thought the OEMs have teflon sides (the grey on each side of the orange)
Old Feb 17, 2009 | 05:51 AM
The pineapple heavy duty coolant o-rings do not require stretching and fit with zero issues, unlike some of the other 'brands' i've been asked to use.
Now i'll use any coolant o-ring a customer wants, as long as it's oem or pineapple
Old Feb 17, 2009 | 09:13 AM
neit_jnf's Avatar
didn't pineapple start using viton coolant o rings instead of teflon? or am I going crazy?
Old Feb 17, 2009 | 12:49 PM
jkstill's Avatar
Searching for 10th's
The heavy duty coolant seals from Pineapple are viton:
http://www.pineappleracing.com/index...PROD&ProdID=99
The word 'viton' doesn't appear on the page, but they are made of viton.
Old Feb 17, 2009 | 01:48 PM
Sponsor
Its viton.
Howard Coleman
The Good Businesses
Sep 15, 2015 10:31 AM
msilvia
15
Sep 11, 2015 12:13 PM
BLK 93
11
Sep 9, 2015 10:56 AM
