whats wrong and what do i need to do?
Old Dec 14, 2002 | 03:36 PM
Angry whats wrong and what do i need to do?
Im pissed beacuse when im flooring it in 4 gear the fuel starts to cut off what do i need to do to fix it better fuel pump what?
Old Dec 14, 2002 | 03:45 PM
REVHED's Avatar
Hunting Skylines
Assuming the filter is clean then you definately need a better pump.
Old Dec 14, 2002 | 05:17 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
You didn't say what motor/intake setup you are using, but if you're using pretty much any aftermarket carb, and/or a ported motor, you most likely need a higher volume fuel pump, like a Holley.
Another option is to run two stock fuel pumps in parallel.
I'm currently using an RX4 pump on my stock 12A with stock carb just because the RX4 pump has to supply the thirstier 13B, so I figure it's a good measure. I haven't had any fuel delivery problems, so I suppose it's worthwhile. Good luck. -WG
Old Dec 14, 2002 | 07:19 PM
specRX7_22's Avatar
ive had the best luck with the Carter pump. that thing is rated for like 30psi, so a fuel pressure regulator would definately be recommened with it.
--eric
Old Dec 15, 2002 | 03:30 AM
you didnt say if you were useing a aftermarket carb or not... if your useing the stock carb check the fuel filter... hell if you have never replaced them before its a good idea to do so
dona1326cosprings7
Oct 29, 2015 06:47 AM
pfsantos
Sep 30, 2015 01:29 PM
