Why does my gsl-se keep flooding?
Old Dec 6, 2002 | 06:06 PM
ioTus's Avatar
'84 5-letter
So i go into the mall, enjoy playing some envigorating rounds of DDR w/ my buds, then come back out to my hot ride to go home.
But it doesnt start, cause its flooded. This is the 3rd time this has happened, why does it flood? What are causes of flooding?
Old Dec 6, 2002 | 06:14 PM
RotorMotorDriver's Avatar
Seven Is Coming
Maybe you have some leaking injectors?
~T.J.
Old Dec 6, 2002 | 06:15 PM
Project84's Avatar
Open up! Search Warrant!
GSL-SE= fuel injected. May have a leaking injector.
Old Dec 6, 2002 | 06:19 PM
Seven Is Coming
BTW, who plays DDR anyway .
~T.J.
PS - That is Dance Dance Revoloution right?
Old Dec 6, 2002 | 06:26 PM
RacerX7fb's Avatar
paradox
The fuel injectors must be leaking . They tend to do that after time. If that's the case you will have to send them out to be blueprinted or get newer ones.
Old Dec 6, 2002 | 07:29 PM
rotor vs. piston's Avatar
Function > Form
Not sure what the actual problem is, but I can offer a "until you get it fixed solution." When your car floods out just pull the fuse for the injectors, crank for a few seconds and replace the fure and vwala. Some people wire up a switch for their injectors because of that problem.
Old Dec 7, 2002 | 12:12 AM
zookeeper's Avatar
Retro Rocket
Check this site out for flooding concerns:
http://www.rx7.com/tech/index.html
NickNac113
13
Oct 1, 2015 09:25 PM
