5th gear synchro
5th gear synchro
Got into the tranny and the 5th gear synchro out with no problem. Thought someone might be interested in what a bad one looks like. It was broken in two places but only one break was all the way through so the piece didn't drop into the tranny. When I got it out I pulled on it a liitle bit and it broke in half. The moral being if you hear it grinding into 5th DON'T force it. If the ring broke in half I would have had a lot more damage.
Trending Topics
Missed the 2-3 shift at the strip in Epping NH and hit 5th but it didn't go in. It only took one time and it wouldn't go in to 5th again. I updated the shift select spindle with the synchro repair. The new version is supposed to have a stiifer spring.
Thanks j9fd3s I'm definitely going to go into the tranny further with that advice.
Jim
Jim
You might want to consider changing your 5th gear ratio while you're in there to make it not suck so hard.
I'm doing mine right now and I'm putting in a .806:1 rather than the stock .719:1
This will give me a more useful 5th.
Brian
Brian
yeah mine is shot too I think. For me to get into 5th though I just wait a sec. or two and then shift 4->5 and it doesn't grind then. So maybe it's not hurt too bad.
Wargasm,
Is that a stock gear from some other tranny or did you have one made?
shmaLbus,
Not difficult and really no special tools needed that you can't make yourself to get at the synchro ring.
Jim
shmaLbus,
Jim
From: "Forecast for tomorrow, a few sprinkles of genius with a chance of doom!"
Is this problem with all Fds of just specific(sp?) years. Not to sound stupid, but how would you double clutch. are you taking about like the big rigs, where you got to press the clutch twice, or is this some racing terminology
Originally posted by SanJoRX7
FYI, there should be a 4 after 3, but before 5. That could explain the grinding
mike
