front fender lip rolled??what the ??
Old Aug 5, 2001 | 02:20 AM
clearthinker's Avatar
I've seen this on the forum before but never a detail explanation of what it means...what kind of bodywork is this?
any disadvantages....
why do this....
Old Aug 5, 2001 | 02:55 AM
ek9220ps's Avatar
it means to roll up the fender so the tire wouldn't rub the fenders
if its not done right u will see waves or the fender or quarter panel will not be even
Old Aug 5, 2001 | 03:30 PM
Blade7's Avatar
WTF!! You didn't explain how!! yeah everyone knows that it is done to gain more clearance BUT, HOW? How does one do it? What are the steps!!
thanks
Old Aug 5, 2001 | 04:13 PM
black99's Avatar
Lurking..................
Re: ?????
thanks
Keep coping an attitute and no one will show you...
Old Aug 5, 2001 | 04:57 PM
ek9220ps's Avatar
There is at least 3 ways to do it.
1. Buy a $900 fender rolling tool.
2. Take it to a body shop and have them pound it out.
3. Use a baseball bat.
1. Don't try to do too much too soon. Take your time to avoid cracking the paint on the inside of your fender. Coated the lip with some black under-body protector to hopefully keep it safe from rust. It may also help to use a heat gun to warm the paint before working on it to make the paint somewhat more flexible.
2. Put a rag between you car and the bat... this will keep the paint from the bat form damaging the paint on your car.
3. You'll constantly need to raise and lower your car with the jack in order to get the bat in and out of the fender... make sure you have your wheels chocked so your car doesn't roll back unexpectedly.
4. Only roll as much as you need to! Don't risk cracking the paint by trying to roll the whole lip. I've been told that you only need to roll the very top of the lip. I'd suggest rolling a little, then drive your car to see if you've cured you problem.
5. Make sure you have a small chair available or your back will be killing you from bending over!
Good Luck!
Old Aug 6, 2001 | 12:50 AM
HedgeHog's Avatar
Rotary Poseur
I'll go backwards from the previous post....
3) The baseball bat thing will work put will prolly crack your paint. Hard to control and go real slow....it's not very neat but will give you the clearance. (don't ask how I know )
2) When "tapping" the fender lip out, watch out for the fender liner screws that fasten them to the fender. A good hit will result in a zit popping out of your fender. (again, don't ask how I know )
1) You don't have to buy it. Tire Rack rents this tool out with a video and a heat gun. The heat gun softens the paint so it's more pliable. The tool clamps to the bolts on the rotor hat and has a roller that clamps to the fender. You then 'crank' this roller through the arc of the fender. The tool is made by Haweka.
Good luck...
Old Aug 6, 2001 | 01:07 AM
whooly Sh@#
What the hell are you guys talking about....bats, heat guns on my baby. Are you nuts?....no really, it sounds just a tad scary to be batting the hell out of my car.
Has anyone had a body shop do this?? I know the sheetmetal on the FD is very THIN!!
Anyone with some pics or diagrams???????
Old Aug 6, 2001 | 03:14 AM
dclin's Avatar
Perpetual Project
Re: whooly Sh@#
Uhh, actually its quite thick, very stout - at least the part you want to roll anyways, grrr. See http://www.overboost.com/story.asp?id=131
Old Aug 7, 2001 | 03:11 AM
yomamasmama's Avatar
don't do it yourself if your afraid of screwing it up
let the body shop screw it up for you
Old Aug 7, 2001 | 07:34 AM
FastX7's Avatar
I've seen some really nice fender rolling jobs done. A guy I know had the fenders on his 300zx rolled to fit 17x11's in the rear. It'd been repainted afterwards, but I'm sure a job that big cracked the paint. I think it's definitely worth the time/money if the jobs done right. It adds so much to the appearance of the car and gets rid of any rubbing sounds or slashes in the tires.
Th0m4s
Feb 26, 2019 02:04 AM
