Efini Y Pipe
Old Nov 24, 2002 | 10:58 PM
SilvioRX7's Avatar
Question Efini Y Pipe
Whats the difference between the stock Y pipe and the Efini?
Old Nov 24, 2002 | 11:02 PM
P'cola FD's Avatar
Hamado things my way!
The enfini Y pipe has an aluminum crossover tube, and does not use a rubber coupler to the crossover tube, but rather bolts to it.
Old Nov 24, 2002 | 11:37 PM
SilvioRX7's Avatar
Are there any performance gains using the Efini?
Old Nov 24, 2002 | 11:46 PM
adam c's Avatar
Cheap Bastard
I was just about to answer your question when I saw your avatar. That's pretty offensive. This is supposed to be an adult site where people exchange usefull information. I suspect some people, like me, won't want to help you after looking at that.
Old Nov 24, 2002 | 11:56 PM
CowsniperRX7's Avatar
Rear Admiral
I also wondered how you could get away with that. Please change it. I don't want to look at some stick figure wacking off every time you post.
Old Nov 25, 2002 | 12:30 AM
SilvioRX7's Avatar
CowsniperRX7/adam c: No one else has seemed to mind it. I guess you 2 are the type of people that walk around with a stick up your a$$ all day long. Lighten up and what my avatar looks like
Old Nov 25, 2002 | 05:28 AM
SleepR1's Avatar
Thumbs down I don't like your avatar either...
It's only a matter of time before an admin makes you change the stick figure to something else...
Old Nov 25, 2002 | 06:33 AM
SilvioRX7's Avatar
For all you sensitive folks out there, I changed my avatar so no one else will get offended(boo hoo )
Old Nov 25, 2002 | 06:48 AM
skunks's Avatar
I'm a CF and poop smith
The y-pipe is a good mod but its a real bitch to install, I did one for a friend and it turned a simple 1/2 an hour non-seq conversion in to a 6-10 hour horror story. I suggest taking off the airpump if you do this mod first. Also, there are no performance gains, all it can give you is the relibility that your cross over pipe won't leak or pop off.
Good luck
Old Nov 25, 2002 | 06:55 AM
SleepR1's Avatar
Cool Thank You
it's not about sensitivity, it's about respecting others...
Now to your question...Mazdaspeed Motorsports Development claims a 10-hp increase with using an Anfini Y-pipe...
Old Nov 25, 2002 | 06:56 AM
tcb100's Avatar
DinoDude
Mazda Comp claimed a 10HP gain. I don't recall the install as being that bad but plan on an afternoon. Do get the airpump out of the way & use a metal gasket to connect the pipe to the turbos.
Old Nov 25, 2002 | 07:54 AM
ttpowerd's Avatar
HARRRRRRRRR
you get some more power out of it, at least I felt it. You need to remove the intake, airpump, and rear turbo air inlet. It is really not that bad but I would plan on about 1 hour. It took me slightly less the second time I did it but still a PITA because you have to remove a lot of stuff that's in the way.
Old Nov 25, 2002 | 08:11 AM
SilvioRX7's Avatar
Thanx for the info guys. Whats the price tag on that Y pipe?
Old Nov 25, 2002 | 08:12 AM
ttpowerd's Avatar
HARRRRRRRRR
hahaha....look for it.
www.rx7store.net
Old Nov 25, 2002 | 10:35 AM
cover8's Avatar
consider what kind of intercooler you will use later as this may pose future problems with some ICs (i.e. M2)
Old Nov 25, 2002 | 10:37 AM
Flybye's Avatar
It's never fast enough...
I also noticed a nice boost in power when I installed mine. Enough to the point where I needed to adjust my boost controller because I was still using the stock ECU back then.
Old Nov 25, 2002 | 10:45 AM
RonKMiller's Avatar
Blow up or win
Well, at least we now know what you do in your spare time.
Old Nov 25, 2002 | 01:55 PM
Goober's Avatar
de doober
I currently have a med M2 IC and was interested in picking up an efini y pipe. But M2 says that some modifications would be required to make them work. Has anyone that has a M2 med IC installed a Efini Y pipe? If so what exactly did you have to do to it?
Thanks!
Old Nov 25, 2002 | 02:00 PM
SleepR1's Avatar
I think you have to cut off of the cross over pipe, so you can hook up the M2 IC pipe??
Thanks!
Old Nov 25, 2002 | 02:01 PM
SleepR1's Avatar
Rx7 Store
doesn't have the bottom part of the Efini Y-pipe--it's on backorder.
FWIW, Jason has a nice polished set, but again only cross over pipe is available. The bottom part which is the Y-pipe is on backorder from Mazda...
www.rx7store.net
Old Nov 25, 2002 | 02:05 PM
SleepR1's Avatar
Jason has the best deal at $225, and a fully polished version at $299. SR Motorsports sells the Efini Y pipe for $245. If you're a Mazdaspeed Motorsports Development member, the Y pipe is <$200. Mazdaspeed won't have the Efini Y pipes available until the first of the new year 2003...
Old Nov 25, 2002 | 05:05 PM
skunks's Avatar
man, you guys must have been leaking bad or something because how does replacing a pipe (which is damn near the same size) give you any more power???
BTW: is this the butt dyno talking or do you got actual proof via a real dyno? If this is the butt dyno talking, I got a sweet *** set of stickers that will give you about 30-50 more rwhp, it only cost 100 bucks
Personnaly, I don't know anybody that can tell if you got a 5-10hp increase in hp by just driving the car after you install something. The weather getting colder at night probally give you more hp then the actual mod hehe.
Old Nov 25, 2002 | 07:52 PM
gohorns's Avatar
The efini ypipe will usually increase boost by 1psi which will lead to power gains.
Old Nov 25, 2002 | 08:23 PM
SleepR1's Avatar
gohorns
short...sweet...accurate...way to gohorns
Old Nov 25, 2002 | 08:43 PM
turbojeff's Avatar
Do it right, do it once
~4yrs ago I added the Efini pipe to my 93 R1 when it was completely stock. A completely stock car usually runs out of breath around 6800-7200rpm. Adding the Efini pipe seemed to give a little more breathing room at the top.
As to how it adds power being almost the same size, here are a few reasons...
The rubber coupler on the stock plastic pipe don't really help flow. Under boost the coupling hose will expand away from the pipes it is clamped to, this makes for very rough pipe that the air has to flow through. The Efini pipe has a larger ID where the cheesy plastic mount fits on the original crossover pipe. Finally the y-pipe itself is slightly different, the nipple for the BOV sticks into the stock casting farther than it does on the Efini pipe. Finally it fits really nice compared to the original pipe. That is the main reason I like it so much.
Jeff
