question about removal of rotors and hubs???
Old Nov 21, 2002 | 05:12 PM
Rx-7Blazin's Avatar
hey does anyone know how to remove the rear huds??? i have the calipers off and cant get the rotor and hub off the axle, is there any special way to do this?? please help
Old Nov 23, 2002 | 12:48 AM
maxcooper's Avatar
WWFSMD
What kind of car do you have? If you just want the rotor off, you should look for a little threaded hole on the rotor. Put a bolt in there and it will pop the rotor loose. Get a Factory Service Manual if you want to get the hub off.
-Max
Old Nov 24, 2002 | 11:22 AM
dvls-7's Avatar
Sick & Twisted
-Max
ditto....some more info about your car will be helpful....there also might be two phillips head screws pull those then if the bolt trick does not work then u have to go the old fashioned way....hit the **** out of it with a hammer......BECAREFUL no to hit the studs or the face of the rotor.....jus jar it loose so u can take it off.
Old Nov 24, 2002 | 01:16 PM
Rx-7Blazin's Avatar
its an 87 GXL
cdn
14
Sep 10, 2015 06:23 AM
TheAsset
Sep 5, 2015 04:36 PM
cdn
2nd Generation Non-Technical and pictures
Aug 11, 2015 08:59 PM
