Koyo Radiator install help
Old Aug 3, 2001 | 10:21 AM
Novato's Avatar
Newbie
Question Koyo Radiator install help
Just ordered the 55mm Koyo AL radiator. Can anyone provide some insight into the installation of this item?
TIA
Manny
Old Aug 3, 2001 | 10:43 AM
Dimcorner's Avatar
Man Whore
... That thing is BIIIG!!!
If you have a stock IC it think it's going to push your IC up quite a bit. I have a fluydine and the IC isn't sitting straight.
Old Aug 3, 2001 | 11:29 AM
Novato's Avatar
Newbie
Yeah, I have the stock intercooler. That will be next but here in Texas with 100* daily for the last month, I must get some cooling, pronto.
How hard is it to remove the radiator itself? What do I need to remove to get it out and the bigone in?
The price difference was tiny so I went with the bigger, perhaps not better but it will look phat.
Manny
Old Aug 3, 2001 | 12:02 PM
Bacon's Avatar
IRS 4 Life
just put one in rxrotary's car yesterday...if ur set up stock ur gonna have to drain coolant...remove upper rad hose...airbox...battery&tray....i and duct....u can pull the stcok with or withouth the fans it dosent really matter....the koyo was wierd when i firs put it in it wouldnt sit all the way down...then after alittle wiggling and proding it sat down....slightly higher than stock...pushed the m2 race ic up a bit...
Old Aug 4, 2001 | 12:42 AM
potatobbq's Avatar
Yup, it definately required a bit of effort getting that thing in there... I actually had mine done at a shop today and they drilled new mounting bracket holes on the radiator to get it to sit as far down as possible and it STILL pushes up the IC quite a bit. Yup, the radiator is just BIG... Anyone else have the Koyo in the car already? How do you guys like it? Honestly, I'm really not that impressed, but then again I don't have a real temp gauge, only the pos stock one.
Old Aug 4, 2001 | 04:16 AM
potatobbq's Avatar
Originally posted by hksfd3s
The KOYO fits really well. There should not be any problems. Just pull the old one out and put the new one in.
I wish it was that easy to install but it seems like more than a few people are having problems with them. Maybe it's just this recent shipment that has problems. I remember seeing a picture of your car and I saw the Koyo radiator mounted vertically because of your front mount intercooler, did you ever have it mounted in the stock position? I'm curious if you've had yours for a while and maybe it's just this recent batch that has fitment problems.
Old Aug 4, 2001 | 08:10 AM
Novato's Avatar
Newbie
Thanks for all the helpful info. I will be getting it mid this week. The install will be done by myself so I will let you know what problems I run into. My car has the stock intercooler so the rad will be installed on the stock position.
Manny
Old Aug 5, 2001 | 02:17 PM
rxrx7's Avatar
THe install shouldn't be that hard. I didn't put it in, but for someone with experience with the car it shouldn't be difficult. It's big but it did fit in the stock location with no modification. The only thing is, I do have the M2 lg and it puches it up so i had to take my hood prop off and stick it in the trunk.
RotaryBobby
Aug 29, 2015 10:32 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
