Pettit Unlimited ECU question
Old Aug 2, 2001 | 10:55 PM
Pressurized's Avatar
Sorry, don't have a Pettit, wish I did....but I got the M2 13psi ECU and I only had a catback at the time....they said it would be fine, just runs a little rich, bogged down a bit from a stop, it might fowl your plugs....but it's not dangerous, you should have gotten an ECU before those mods you're running now, just to be safe.
As for the Unlimited......from my knowledge when I was looking to buy it...."Unlimited" will accept just about any part you can screw or glue to the car....midpipe, streetport....etc.
But, yes, wou will be more than fine....maybe even better off with the Pettit than the stock ECU....
Also, you might wanna get your fuel filter replaced....
Old Aug 4, 2001 | 10:38 PM
technonovice's Avatar
Jinx
$700 for the Pettit and $1600 for the pfc from RX-7 fashion ans $999 for Farrell's pmc
Old Nov 17, 2001 | 12:56 PM
JoeD's Avatar
Old Nov 17, 2001 | 06:40 PM
badass7's Avatar
Pimpin Rotors...and Hoes
One of my members is selling his M2 14.7 ECU for $550 shipped to your door. Email me at talvendi@cs.com if interested.
Old Nov 19, 2001 | 10:03 PM
From: Minnesota, now in FL and I dont think I'm goin back
Would the Pettit unlimited ECU be enough if I'm putting on a down pipe, midpipe, full catback, intake, and boost controller?
Old Nov 20, 2001 | 12:45 AM
Mahjik's Avatar
Mr. Links
Wink
Yep, you'll be fine.
Make sure you have a Boost Gauge installed, as a Boost Controller will not keep you from having Boost Creep that may come along with a midpipe.
Old Nov 20, 2001 | 02:06 AM
jackc's Avatar
Yes... make sure you have a boost gauge hooked up. When I got my Pettit ecu after the install it was boosting to 17 - 18 pds at WOT.
A Mustang came up beside me while I was testing my new ECU.
I had to hold back and did not get into the second turbo hard. Didn't want to blow up. So I had to let him win. One of the only times I lost to a mustang.
I talked to Jeff and
Cam at Pettit and they got me to install a larger pill in the wastegate line to limit boost a little. I think I run a 67 jet in the
wastegate line now. I run usually 14 - 15 pds. Always with NOS octane boost on a 1/2 tank of 92 octane. But the injectors are at the limit.
If you don't have a boost gauge... you're taking a big chance...
Best wishes Always run with 92 or better gas...!!!
Old Nov 20, 2001 | 02:15 AM
JoeD's Avatar
just run a Dawes Devices MBC...
www.dawesdevices.com
Skeese
65
Mar 28, 2017 03:30 PM
