Konig Imagine Rims
Old Nov 15, 2002 | 03:37 AM
silverrotor's Avatar
Konig Imagine Rims
I wanted to get the BBS RSII's but weighed It out. To pricy and are quite heavy. I still like the look of BBS RSII rims so I'm opting to go with the Konig Imagines, In Silver. Do you think the rims are heavy for 17 x 7? What are your regards on these rims?
Old Nov 15, 2002 | 07:27 AM
Come on boys? What do you think?
Old Nov 15, 2002 | 12:12 PM
ttb's Avatar
ttb
No Cup Holder Racing
7 is kinda narrow. stock is 16 x 8. otherwise looks okay.
Old Nov 15, 2002 | 12:13 PM
ttb's Avatar
ttb
oops, this is for a FD?
Old Nov 15, 2002 | 12:22 PM
ARD T2's Avatar
Even for an FC that is quite narrow. You'll need to look for an offset of +35 or so.
When this issue comes about I suggest staggeriing 17" and 18". This will allow you to get an 18,8 or 8.5 in the rear and the 7" will be fine up front. Then run a 215/45/17 and 235/40/18.
Rishie
Let me know if I can help at all. I might have some other options for you as well. What's the color of the car?
Old Nov 15, 2002 | 09:41 PM
My 88 GXL Is 1999 Mazda Miata Highlight Metallic Silver. I have B&G Lowering Springs on that lower my car 1.5". So I have to consider that Into the equation aswell.
I am dead set on getting 17' rims on all 4 ends. I currently have 16' Anterra's at 205/55/16. Although the wheel wells filled considerably, I want 17's all around. I was thinking 215/45/17 (front) 225/45/17 (rear).
What do you think? Is that a good preportion? I'm concerned about narrowness now. (Good point guys). How does my potential setup look to be?
Old Nov 15, 2002 | 09:45 PM
Perhaps this could help additionally. Don't forget I'm looking for Imagines.
http://www.tiredex.com/konig/app_gui...RX-7&B1=Submit
Old Nov 16, 2002 | 12:59 AM
Mazderati's Avatar
If you end up going with a set of Konig Imagine wheel I have a set for sale. 17x7, 5x114.3. They don't have any flaws whatsoever. They were on the car for 3,000 miles. Thanks.
Kyle
Old Nov 16, 2002 | 05:14 PM
Cool. Good to know that I have this hook up. I understand 17x7, In terms of size, but what does 5x114.3 mean? Is It for all 4 rims? Sorry If I appear as a tart.
Old Nov 16, 2002 | 05:23 PM
Mazderati's Avatar
5x114.3 is the lug pattern. You have 5 lugs with a spread of 114.3 between them. Thanks.
Kyle
Old Nov 19, 2002 | 02:09 PM
ARD T2's Avatar
The way I would highly recommend doing this on the FC to have a good setup is to go with the 17,7's up front and the 18,8.5's in the rear.
Then you should run a 215/45/17 and 245/35/18. This combination would be great. Plus you'll have the proper stagger effect.
I run staggered diameters on all my FC's for street and show. They work great. It's really the only way to get a good looking fitment with knockoffs.
Rishie
Old Nov 19, 2002 | 03:57 PM
Rishie///thanks for the recommendation. This sounds like a solid setup that I'm likely to go with.
When you say this setup will give me a proper stagger effect, what do you mean exactly? Balance and proportion?
Old Nov 19, 2002 | 07:23 PM
ARD T2's Avatar
Kind of everything. The 17,7 in the rear would have looked like it sat in the fender about two inches. with the 18's back there it will look like a proper fit.
I'll see if I can find pics of my car and show you.
Thanks, Rishie
Old Nov 19, 2002 | 11:17 PM
Cheers!'s Avatar
Former Rx7 *****
i thought the ideal setup for Fcs was
17x8 in front
17x9 in back
Old Nov 20, 2002 | 02:49 AM
ARD T2's Avatar
Oh I'm talking pure aesthetics and by following the patterns in the "knockoff" industry this is virtually the only way to acheive a good staggered fitment. Fortunately, a staggered 17, 18 combo is becoming of the FC.
Cheers you are totally right in the handling department, but unfortunately it's very difficult to get that combo in comparison to finding staggered width from 17 to 18 diameters.
He chose the imagines and being that it is a gorgeous style, Enkei Aegis knockoff, I looked into it previously and came to the conclusion that if I were to use this wheel that's what I would have to do. Otherwise it just doesn't work too good.
In my opinion the best bang for buck in the wheel performance dept is the FD wheel on the FC or another lightweight wheel that's 8 - 8.5" wide. Like the Kosei K1. 16,7.5 and 8.5. That would be great.
Old Nov 20, 2002 | 03:40 AM
Mazderati's Avatar
Actually, I think the Konig Imagines are a supposed to replicate the Work Rezax IIs.
Also, I wouldn't spend the money on Konig's "Black Opal" finish. It is hardly any darker than the silver finish and doesn't really look anything like what advertisements show. Save yourself the money or have them finished somewhere else once you get them.
Kyle
http://www.work-wheels.ch/rezax2.htm
Old Nov 20, 2002 | 07:58 AM
I do plan on getting the Silver's. Not the Black Opal's. I do agree, very little diffence In contrast.
With the suggested, 215/45/17 and 245/35/18 for my FC, would their be compromise In handling? Surely your setup Is definetly a good one In terms of asthetics but handling Is just as much considered for me before I'm a go on theses rims. What do think? Also, keep In mind my car had B&G Lowering Springs that has dropped my car 1.5 Inches.
Old Nov 20, 2002 | 06:49 PM
Max7's Avatar
Admitted Sevenaholic
I like them I agree don't get the black opal finish.
as for weight, I got them in 17x7's with 205/45/17 Toyo RA-1's
and ended up being 2 pounds lighter than my old Eneki RSE 16x7's with 205/45/16 Nitto 555R's
they are a bit to keep clean, the bolt holes always hold dirty water and after a wash they seep and you need to clean them again.
Old Nov 20, 2002 | 07:47 PM
ARD T2's Avatar
The handling will be great. I currently run a 17,8 and 18,9.5 with 225's and 255's. I love the handling. It looks and handles. Great for the street. 17's staggered in the same wheel would be lighter and you'll have a little more sidewall as well. This will help in the handling of the vehicle.
Rishie
this is the Aegis. I'm sure it resembles a few mesh wheels.
Old Nov 20, 2002 | 09:36 PM
Thanks your responses. I'm going with the Imagine's. I'm going staggered. I'll keeo you guys posted.
Old Nov 21, 2002 | 09:13 AM
dvls-7's Avatar
Sick & Twisted
You will like the Imagines.....i have a set also.....18s all the way....runnin 215/35 up front and 245/40 in rear next set of tires i might go with 225/40 f and 255/35 r
Old Nov 21, 2002 | 11:32 AM
Good to know you are also happy with the Konigs too.
Old Nov 21, 2002 | 10:55 PM
Thanks, Rishie
Any Pics yet Rishie?
Old Nov 22, 2002 | 05:24 PM
Hey Rishie, you suggested an offset of 35 or greater. 38 Is what the Imagines offer. Under the link, It suggests the possible Tire uses and It does not list any 245's as an option.
Am I looking at It all wrong or can you fit 245/35/18 on 18x8.5 rims with an offset of 38? This, right now, Is whats seperating me from getting these rims. Hope to hear from you soon.
Heres the link again. http://www.tiredex.com/konig/app_gui...RX-7&B1=Submit
Old Nov 24, 2002 | 05:18 PM
^ cause I wanna know.
Rotary12Ahead
Oct 29, 2015 03:16 PM
NickNac113
13
Oct 1, 2015 09:25 PM
Turblown
Sep 30, 2015 05:58 PM
