replacing PFC with stock ECU help
Old Nov 10, 2002 | 02:51 PM
mazdaspeed00's Avatar
For Sale
i cut the 4 wires needed to make my fd run better whe installing the PFC
4F - Split Air Bypass Solenoid Valve Output
4O - EGR Solenoid Valve Output
4P - AWS Solenoid Valve Output
3J - EGR Switch Input / DRL Input (Canada)
what would happen if i didnt reconnect these wires if i were to installed my stock ecu?
thanks
For Sale
would my car running on the stock ecu with the cut wires perform any worse?
Old Nov 10, 2002 | 04:56 PM
Lost Time's Avatar
Chimera Driver
It's just emissions crap. Don't worry about it.
Old Nov 10, 2002 | 09:04 PM
Tom93R1's Avatar
gross polluter
It should just be the EGR valve that is disabled but I don't know if the CEL will flash or not. I am interested also because I pulled the wires out of the connector before it hit me that pulling the pins from the PFC would be a better idea
Old Nov 10, 2002 | 10:19 PM
For Sale
anyone else have any imput on this?
the PFC makes a world of difference. i put the stock ecu in and my car dosent idle as good as before.
Old Nov 11, 2002 | 06:56 PM
For Sale
would i still be able to pass emmissions with these wires cut? i only have a DP.
Old Nov 11, 2002 | 08:34 PM
duboisr's Avatar
Put male female plugs on the wires and plug --un plug as needed per ECU . That is what Garfinkle does when he installs the PFC.
cristoDathird
28
May 30, 2019 08:47 PM
torky007
Aug 17, 2015 05:14 PM
