So I need a new engine, do these prices seem right?
Old Nov 10, 2002 | 02:36 PM
DRAG0NEER's Avatar
Hi all I blew the water seals from overheating so now I need a new engine. My mechnic to me that I have 2 options:
1. $4500 for a Mazda reman including removal and install. He recommended me this route since he said the remans that he got lately looked very good (new housings....)
2. $6000 for him to rebuild it (new rotors, housings, seals...etc.)
He's a very reputable rotary tech here in the bay area and I was just wondering if these prices seem right? Or should I just get it from Malloy or pineapple and just having him do the install?? And what is the average (reasonble) labor charges for removal/install?
thanks
Old Nov 10, 2002 | 03:12 PM
nocab72's Avatar
03 Cobra Killer
If you are rebuilding an engine, get it ported...you'll be glad you did...even if it is a small street port!
from those prices, it sounds like they are charging about $2000 labor for removal/installation. I don't know if that is good or bad, I did mine myself (with the help of Xavier @ the RX7 store).
K
Old Nov 10, 2002 | 03:23 PM
DRAG0NEER's Avatar
thanks nocab! I sent you a pm did you get it?
I think I'm leaning towards pineapple but I doubt that I'll be doing the removal/install myself. What is the average price for the removal/install? Also, how and what did you used to ship the motor to pineapple? What about the turnaround time? thanks!
Also, my engine is gone due to overheating which caused my coolants seals to go...is my core rebuildable?
Old Nov 10, 2002 | 04:27 PM
GsrSol's Avatar
Z06 powered FD
To me those prices seem pretty high. Your rotors should be fine.
Old Nov 10, 2002 | 04:46 PM
rx4ur7's Avatar
ASIracing charges 3800.00 installed.The install or r&r (remove & reinstall)is $1000.00so their performance motors seem cheaper at $2800.00 than this guys remans .The 3800 includes reconditioned housings and rotors,Hurley 2 or 3mm seals(for 3mm add $75),Hurley side-seals,ported, polished with all new internals including main and rotor bearings,seas,etc..If you are wanting brand new housings and rotors you can expect to pay $2000+ and 99% of all Mazda remans come with reconditiond parts.Regardless the install and removal should be around $1000.00!!
Old Nov 10, 2002 | 04:49 PM
rx4ur7's Avatar
oops, you can ship air from your local airport or depending on where you are, check with greyhound(yes greyhound)for shipping.Other than that you can call a trucking company.
Old Nov 10, 2002 | 06:01 PM
DRAG0NEER's Avatar
okay i just finished talking to the guy and he said for R&R alone would be $1500. The cost of the reman that he's getting is $2700 and the remaining $300 would be the new gaskets and hoses that are REQUIRED when putting the new engine in. Does this sound about right??
So pretty much I'm left with 2 options:
1. go with pineappleracing's engine
2. Get the reman from Malloy Mazda for $1950+shipping
either way I'm still gonna have him do the install since towing my car on a flatbed everywhere for a few hundred bucks each is just not gonna cut it. So guys, help me decide on what I should do!? Which is better? Pineapple or reman from Malloy? What new parts would I be getting from Malloy? From Pineapple? And what would be the main difference? I'm looking for reliability...
Old Nov 10, 2002 | 06:06 PM
ArchangelX's Avatar
Well..I'm exactly in the same boat sorta...Pineapple is currently my fav choice...I've talked to Rob, and he's a really friendly guy, plus all of his work is awesome from all my engine searches on the forum.
I've heard that remans can be really shoddy at times.
I'd go with Pineapple.
Old Nov 10, 2002 | 06:18 PM
DRAG0NEER's Avatar
yes i'm really leaning towards pineapple since I'd like to have a ported engine. All I have right now is intake and full exhaust (dp, mp, cb). My turbos have 65k on them and the turbines looked like new the last time i checked so I doubt that I'll be going single anytime soon (especially after the $$$ spent on this new engine). So I guess the question now is which package should I go with? Should I get their oil mods packages? What kind of porting should I go with for my daily driven 7 with the above mods (IC coming soon)? Any advices would be appreiciated! thanks.
Old Nov 10, 2002 | 06:34 PM
ArchangelX's Avatar
Welps..I guess it totally depends on what you're going for.
Are you looking for serious power with reduced streetability? Or a daily driver with some power to boot.
I think your best bet would be to give Rob a call...he'll tell you exactly what you want from the information that you give him.
I told him that I want a daily driver with the ability to hit high 11's, low 12's, and he recommended the 5yr/60k engine with a mild street port and Stage 2 oil mods.
Either way, you just can't beat his work, and prices...
I can't wait for my engine rebuild!
Old Nov 10, 2002 | 06:49 PM
DRAG0NEER's Avatar
does he give you new housings, rotors, etc...?
Old Nov 10, 2002 | 06:52 PM
nocab72's Avatar
03 Cobra Killer
only if you need them.
Old Nov 10, 2002 | 06:57 PM
ArchangelX's Avatar
Wha? Really..that's not what he told me. He said he uses brand new rotor housings.
Old Nov 10, 2002 | 07:09 PM
karken29's Avatar
Engine Selection/Replacement Costs
I recently did a replacement on my engine and went trough Malloy Mazda Ask for Ray Crowe, Mazda Parts... Great guy!! and he charged me $2070.00 for a Reman Motor. The engine is shipped in a large Black/Gray "tupper ware" container and weighs approximately 210 Lbs. So, you'll have to factor in S/H cost to destination. Also, there's a $1000.00 Core charge for your old motor. Ask Ray to explain how that'll work.
Now, I did dropped in my own motor mainly to save time. My local Mazda guru, Dave at KD Rotary Ask for Dave or Kim is swamped with engine installs. But they both hooked me up with excellent tech advice which resulted in a successful swap with minimum stress
As for price, seems like many shops in the Tri-State NY area are going to around $75.00 hourly labor rates... so you can calculated your costs from that number. Whatever you decide... good luck.
Old Nov 10, 2002 | 07:16 PM
maxcooper's Avatar
WWFSMD
Most builders offer different builds for different goals and budgets. And it depends a lot on the condition of your engine. Sometimes they can be reused, sometimes they can't.
-Max
Old Nov 10, 2002 | 07:21 PM
DRAG0NEER's Avatar
-Max
I understand what you're saying but doesn't he send me the new one first? And if he does send me the new engine first then doesn't that mean I won't be using my OWN rotors and housings?? I'm kind of confused since my mechanic is not going to touch my car before he gets the new engine!
Old Nov 10, 2002 | 07:22 PM
DRAG0NEER's Avatar
karken29: Which company did you use when shipping the engines?
Old Nov 10, 2002 | 07:23 PM
nocab72's Avatar
03 Cobra Killer
I bought a rebuildable core sourced through Pineapple, so if you are sending him a motor it might be a different story...
k
Old Nov 10, 2002 | 07:28 PM
DRAG0NEER's Avatar
okay i don't think buying an engine from VA is gonna work since shipping to CA is gonna be a little too expensive (800+ one way??).
Old Nov 10, 2002 | 07:32 PM
ArchangelX's Avatar
Personally, I find this thread highly enlightening. I've got the cash to get the rebuild done..but noone to install it yet.
Dude..go with Pineapple..it's hella cheaper! Call ROB!! Talk to him..you'll be given peace of mind!
Old Nov 10, 2002 | 07:40 PM
Batmobile's Avatar
A Mazda reman should only be $2400!! and the labor should be around $1000 for the install like RX4UR7 said..well thats what my mechaninc charged a buddy of mine about 7months ago. If you have the money...get the thing rebuild and street port that SOB! Good Luck!
Old Nov 10, 2002 | 07:51 PM
DRAG0NEER's Avatar
batmobile thanks for the advice but thing is - my car is not moving and I just had it flatbed-towed from the ghetto to sunnyvale, and that alone have already costed my 3 bills! The next closest rotary place would be in either Oakland or pittsburg which is so freaking far away...I just want to get this nightmare over with if you know what i mean.
Old Nov 11, 2002 | 11:13 AM
karken29's Avatar
Thumbs up Shipping Company Used...FedEx
Ray Crowe, Mazda Parts, took care of the S/H arrangements and used FedEx to ship my motor. Think my charge one-way was approximately $70.00. Also, he said that FedEx and the other shippers charge extra if they're shipping to a home address . Has something to do with ease of delivery. Also, additional charges are typically added for such things as "delivery truck w/hydraulic tail-gate etc. Whatever the case, don't try to price this out yourself since Malloy will handle all that and seemed to get better pricing both ways than I could. Ray will quote you the shipping charges up-front, arrange S/H both ways and supply the "Return" shipping labels. It worked out great for me since I had allot on my plate and every little extra helped.
One other point I forgot to mention, Malloy uses the MADZA Engine containers for shipping. They're better than a palate, easier to handle for the shipper, and protect the motor from gravity tests !
If you need additiona info e-mail me and I try to help out. Good Luck
Old Nov 11, 2002 | 11:57 AM
lane_change's Avatar
It has begun
I thought about going Pineapple for my motor but went with BNR. They had better prices and is closer to where I live to cut down on shipping prices. He replies to emails very fast and builds the motor for what you want it to do. I am going with his Race Port, which sounds like a huge streetport. I wanted it to be reliable up to 600rwhp. I asked him about needing dowel pinning or hardened stationary gears and instead of taking my money and saying yes, he said for my goals that would be a waste of my money. So that was pretty cool of him, not to take more of my money for stuff that I didn't need.
Just another idea. Not saying anything about Rob at Pineapple, I have heard great things from them as well. Nocab's car sounds sweet. Just giving another option that is a bit cheaper then Pineapple.
My motor is costing less than $3000 race ported with 3mm seals and shipping.
Old Nov 11, 2002 | 12:15 PM
i know where u can get a 60k mile drop in motor very clean. was running when pulled for 2295
