Fcd, Why So Bad?
Old Aug 2, 2001 | 03:47 AM
ROSHX7's Avatar
Fcd, Why So Bad?
This guy I know who has a Rx7 like me, keeps telling me to take my FCD off my car cause it will blow my engine, and says I should get an HKS Fcon instead. Now the FCON, costs an arm and leg, and my car is running fine with the FCD, so why does he keep saying it SO BAD for the car? I'm only boosting 10-12psi with bigger secondaries (680cc) & Walbro Fuel Pump...so that should make it safe enough right?
Old Aug 2, 2001 | 05:20 AM
swoop's Avatar
he doesn't know what he's talking about. the Fcon has a fcd built on to it also..........if it's so bad why is he telling you to get something else, that uses the exact same thing you're supposed to be getting rid of.
Old Aug 2, 2001 | 05:22 AM
RETed's Avatar
You are going to start a whole heated debate on this subject...
Personally, I find no problem with your set-up.
Anyone who recommends an HKS PFC F-CON doesn't know that an A'PEXi S-AFC is a superior and cheaper option...
-Ted
Old Aug 2, 2001 | 11:19 AM
Jerk_Racer's Avatar
Does the S-AFC have a built in FCD? Or would the FCD and S-AFC be used together to achieve some more safety with a slight boost up?
jerk_racer@hotmail.com
Old Aug 2, 2001 | 11:35 AM
1FastT2's Avatar
Nope, you have to go with a seperate one. The second sentence is correct.
Old Aug 2, 2001 | 01:46 PM
Jerk_Racer's Avatar
Thanks. That's what I thought. I'll probably go that route one of these days.
Old Aug 2, 2001 | 02:04 PM
PaulC's Avatar
Three spinning triangles
From: Been all around this world and still call Texas home (Ft Worth)
Plug n Play??? Does that mean a FCD runs on Windows? And if so, is it using the 9x OS or the NT OS????
Just kidding
squirrels
Sep 1, 2024 09:52 AM
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Jmpabon93
Sep 30, 2015 04:57 PM
