84SE - headlights won't go up/down/on...
Old Nov 1, 2002 | 09:49 AM
LongDuck's Avatar
84SE-EGI helpy-helperton
84SE - 162k mi, daily driver.
Before test driving my new fuel injector last night, I could not get the headlights to extend or turn on with either the switch on the column stalk, or the 'cleaning' switch on the dash.
Never had this problem before, and affects both headlight buckets, identically.
Additionally, the parking lights would come on, driving lights would come on, but the headlights would not, even with the lids manually opened by turning the motors. Flashing brights doesn't do anything either, and the headlights worked just fine earlier in the evening.
Checked the fusible links, all 5 tested okay. Doesn't seem to be a fuse under the dash for headlamps, either.
I know it's unrelated to the injector work that I was doing, but could I have bumped something? I spent an hour tracing the wiring, fuses, and fusible links, and couldn't find anything wrong.
Any suggestions? TIA,
Old Nov 1, 2002 | 09:56 AM
brownmound's Avatar
Anytime baby!
It is very common for the "combo switch", the switch that controls the headlights, cruise, signals, and wiper, to get dirty inside over time (18+ years) and fail. It often shows itself as one or more of these things not working or working sporadically. For me, I had the probalem of my brights not staying on, but working in the "flash to pass" mode. Then my wipers stopped working.
To fix it, you need to remove the steering wheel. Get a puller from you local auto place. Remove the plastic shrounds and pull the switch, CAREFUL NOT TO LOSE ANY OF THE BALL BEARINGS. They are tiny. Dissasemble the switch and clean it with contact cleaner. Use a pink eraser to rub the contacts back to shiny new copper again. Grease with a suitable grease and reassemble. Fixed everything for me.
Oh and you might want to check your fusible links first, in the engine compartment. But the switch is a common problem.
Right on.
Old Nov 1, 2002 | 11:27 AM
Suparslinc's Avatar
It's Back!
Does the -SE have fusible links???
Mike is right but I would do a little less and try to spray off the multi-switch before taking it apart (PITA)
Old Nov 1, 2002 | 11:33 AM
error402's Avatar
#!/sup_mod/üb3rg33k
Yes.
-Error402
Old Nov 1, 2002 | 11:58 AM
brownmound's Avatar
Anytime baby!
Oh I just read that the cleaning switch didn't pop em up either...well in that case it's probably not a failure of the combo switch, unless it's demise would somehow impair the other switch from working...hmm...i would recheck the fusible links and fuses first...
Old Nov 1, 2002 | 12:49 PM
LongDuck's Avatar
Will do. Might be a bad connection somewhere under the dash. I'll look when I get home tonight. Thanks for the help, guys,
wa11yba11s
Oct 16, 2015 09:54 AM
<<Ayrton>>
Interior / Exterior / Audio
Sep 5, 2015 09:38 PM
