i just bought an 87 t2 and i have some questions....
Old Jul 30, 2001 | 11:46 PM
Suparslinc's Avatar
It's Back!
Locate the vacuum leak first. This can be done with some flammable liquid like WD40. Spray it all around the intake and such; the idle should jump a little when you hit a vacuum leak.
If that doesnt' solve it, inspect all your vacuum lines for cracking or loose connections.
Or, remove your intake manifolds, buy new gaskets, clean up the runners and ports while your at it, and put it all back together the way it came apart. Run some Techron fuel injector cleaner through it. I recommend a bottle with about 6 gallons of gas.
Taking the intake apart is a bitch though.
MikeTee55
Sep 8, 2015 08:05 PM
