what suspension are u guys using on ur SAs?
Old Oct 23, 2002 | 03:11 AM
Kuhrazy7's Avatar
Hey uhm... i was wondering wut suspension u guys were running on ur SA's. Im gonna get some sleeves and some shocks and weld them in the front as coilovers but i was wondering, wut springs and shocks are u using in the back. I need a good spring and a good shock that will last because ill use the same shock for the base of the front coilovers as well, ill help greatly appreciated.
Old Oct 23, 2002 | 04:13 AM
someone82's Avatar
To awnser your intiall question here is my setup:
KYB GR2 Gas Strut inserts
Suspension Tech. Springs
Prothane Front Endlink and Swaybar bushings
83 (i think) GS rear end with rear Sway Bar removed
Bilstein Rear shocks (soft, but they don't bottom out)
Sumitomo HTR 200 195/50's
Custom Rear Shock tower bar
It rides smooth, but handles great, I can whip the tail out with just enough throttle, but it's doesn't push (understeer) through the turns. It's just slightly loose, the way I like it.
I would tho like to reduce the body roll a bit more.
matt
Old Oct 23, 2002 | 06:01 AM
ioTus's Avatar
'84 5-letter
Well, the parts are in the garage, but when i'm DONE i'm going to have:
Tokiko Illumina shocks
Eibach pro kit springs
racing beat front swaybar w/ bushigns
and a few extra poly bushings here and there.
It should be real nice.
Old Oct 23, 2002 | 11:52 PM
Kuhrazy7's Avatar
Thanx for the help, kinda disapointed to hear bilstiens were soft tho, i thought they were stiff+ i wasnt sure if they hadem for the fb, so thx alot guys
Old Oct 24, 2002 | 01:15 AM
someone82's Avatar
The don't have bilstiens for rex as far as I know.. they were off a junkyard rx7 and I thought it was pretty werid. It's soft but, when I switched them in... the rear end was much more predicatable.
got them for 5 each so I was like why not
I'm thinking of getting racing beat rear springs soon tho.
matt
Tylerx7fb
39
May 27, 2019 12:45 PM
Clacor
Aug 14, 2015 09:17 AM
