Please help me
Old Oct 17, 2002 | 09:27 PM
sanchozx9's Avatar
Angry Please help me
I have a 1987 mazda rx7 turbo 2 and it wont start. I checked the fuel pump and it works fine, I smell gas and every once in a while it will almost start but then nothing. I have tested the distributers wire and plugs and all work fine. when I try starting it gas leaks from the passenger side underneath the car. I don't know if the fuel injectors are clogged or what. Any info would be appreciated.
Thanks
Old Oct 17, 2002 | 10:02 PM
Scott 89t2's Avatar
SOLD THE RX-7!
whoa. gas leaks are not good! don't even try to start the car till you figure out what the leak is. it might be the PD damper, which is on the fuel rail.
once you fix that. it sounds like your car is flooded.
Old Oct 18, 2002 | 01:55 AM
FC Drifter's Avatar
Damaged Little F*cker
yeah, check that leak first, and fix it. but other than that it sounds like your flooding the hell out of the car.
Old Oct 18, 2002 | 03:01 AM
bingoboy's Avatar
Lava Surfer
For info on the Pulsation Dampner you can check here:
http://home.earthlink.net/~burntoast...iondamper.html
Old Oct 18, 2002 | 08:34 AM
RylAssassin's Avatar
K well yeah that fuel leaking should be looked at ASAP
But after that try this its a Basic unflooding procedure:
1) Pull your EGI fuse under the hood
2) Turn your ignition while holding down the accelerator for 15 seconds, AT THE SAME TIME
3) Replace EGI
4) Try to start car
It may take several attempts, It took me 6 tries but she started up, and now shes running beautifly now
If this doesent work your going to have to try the Complex version. This all can be found at www.rx7.com under the tech section
Goodluck!
