O2 Sensor... easy installation?????
Old Oct 17, 2002 | 01:23 AM
OK, I just got done installing a new O2 sensor. I must say that I am good at working on cars too. This was a huge pain in the butt. I removed all of the heat shields and it was still hard to tighten the new O2 sensor. I finally had to cut the wire and wrap it around the actual sensor. I found that it was easy to tighten when doing this. I then soldered the two leads together and voila!! I was done. Did anyone else find this difficult?. I reset the computer by disconnecting the battery and holding the brake for 20 seconds. I hope this gets rid of my "code 17"
Old Oct 17, 2002 | 08:31 AM
4Fun's Avatar
Dont make me Laugh
My O2 was just as bad , but I got a bloody knuckle from taking the heat sheild off. That thing is sharp!
Old Oct 17, 2002 | 09:59 AM
RaceReadyRX7's Avatar
Do you have a downpipe? With a downpipe there are no heat shields in the way. Mine was very easy to replace.
Old Oct 17, 2002 | 10:38 AM
RonKMiller's Avatar
Blow up or win
Guys, you're working way too hard.
Just push the heat shield out of the way (hey, it bends) with a deep well socket (23mm?). Cut the lead, spray with Liquid Wrench, wait 5 minutes and out it comes. Crimp a butt connector on the new lead and put a piece of heat shrink on it. The heat from the exhaust will tighten the heat shrink in about 15 minutes.
Or you can buy a special O2 socket for about $5.00 that will sit in your tool box for 5 years after using it once -and skip the above cut and crimp.
If you have a dp put the old heat shield back on and secure it with one metal "Thermal Tie" available at any hot rod shop. You'll need one at least 18" long to fit around the pipe. The shield protects some wiring and tubing on the fender well from getting roasted over time.
Oh, and we did remember to put high temp anti-sieze on the threads, and just snug it down until it gently seats, right?
Old Oct 17, 2002 | 10:44 PM
ofcourse I used the anti-seize and no, I tightened it to 15 ftlbs of torque. Thats what the instructions said
Old Oct 18, 2002 | 12:12 AM
Zoomspeed's Avatar
Or you can rent it form autozone for free.
Old Oct 18, 2002 | 12:34 AM
Tom93R1's Avatar
gross polluter
You can rent an O2 sensor socket? You must really be cheap to know that
I bought one a few years ago and all my friends borrow it. Am I the only person that owns one of these?
Old Oct 18, 2002 | 12:43 AM
Stevil's Avatar
I bought one. You just never know and its inexpensive.
Steve
Old Oct 18, 2002 | 12:59 AM
Zoomspeed's Avatar
LOL yup I am. MY reasoning is $5 for O2 sensor socket, OR $5 for gas. lol
SakeBomb Garage
Vendor Classifieds
Aug 9, 2018 05:54 PM
Under PSI
19
Sep 23, 2015 11:47 PM
galvatron10000
Canadian Forum
Sep 8, 2015 08:50 PM
