Project Kramer update with Pics!
Old Oct 13, 2002 | 06:04 PM
Directfreak's Avatar
I am a Jeeper Now.
Thumbs up Project Kramer update with Pics!
I know it's been a while since I've done a real update on my Project "Cosmo" Kramer, so here it goes, with Pics and all. Progress is steadily improving..
I' am coming after ya Mike!! - J/K.
A Work of Art – Cosmo 13B-RE Intake.
Greddy Elbow (with Larger FD Throttlebody )
3 MSD 6AL's on custom made bracket (Tiiiiight fit) One Leading, Two Trailing.
Custom made MSD Ignition box Bracket. Using the rubber isolators too! I have to relocate the horns somewhere else though.
What MSD's? No MSD's here.
Crispeed Fuel Rail (-10AN)
Secondary Fuel Rail installed
Welded Bungs on Intake for Fuel Injectors. No Leaks here…
Old Oct 13, 2002 | 06:10 PM
I am a Jeeper Now.
Racing Beat Oil Pressure and Temperature Adapter . I need to make a spacer for the third bolt.
A/C Electric Fan, turns on only when the A/C compressor is on.
J & S Knock Safeguard. Knock sensor on rear rotor.
Intercooler Test Placement.
Haltech E6K Placement. Those are Autometer EGT, and Fuel Pressure Senders on the left.
Old Oct 13, 2002 | 06:11 PM
I am a Jeeper Now.
Spider Web. Several Gauges, lighting, additional wiring all over the place.
Additional Fuse Panel from Painless Wiring in glove box for easy access. The wiring of the Haltech and other goodies is totally independent of the stock wiring harness. All Color Coded, so there will be no surprises later. I have not spliced into the stock wiring harness at all, (so far, and hopefully won't have to…)
Profec B Boost Controller. Additional Fuse Panel is covered. All in the glovebox, Out of sight, yet easily reached.
Relocated Battery to Passenger Bin. Not presently strapped down. I had to cut out the rear of the bin for it to fit easier.
I am a Jeeper Now.
A Quickie of the interior. Still far from finished.
A Wider shot of the interior.
Another one.
I still need to install the Reverse Indiglo Gauges from S/R Parts
Did I mention that these things are simply BAD-***? And that Pictures do NOT do them justice?
G-Tech Competition. (lights up Indiglo Blue too )
Wide Angle Rear view mirror, to avoid blind spots. Radar Detector over it, Not that I need it..
Old Oct 13, 2002 | 06:31 PM
Manntis's Avatar
add to cart
Looking very, very good! Nice attention to detail.
A few kweshtins:
Izzit possible to locate the intercooler atop the engine as in the TII? The Mazda reason for doing so is less pressure drop that would be caused by longer plumbing.
Did the tri-gauge bracket I sent you arrive? If so, would you be willing to do a test fit with 3 gauges installed in the facia and snap a photo for me?
Old Oct 13, 2002 | 06:38 PM
Felix Wankel's Avatar
Super Newbie
TMIC's suck. They heat soak majorly.
Old Oct 13, 2002 | 06:39 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
So your using the small NPR IC? That one dont look black like the one I sent you
Looks good tho,
PS Make sure the driveshaft is very very nice.. It will break on you LOL
Old Oct 13, 2002 | 06:46 PM
setzep's Avatar
Re: Project Kramer update with Pics!
[i]Originally posted by Directfreak
[/B]
That wont be too hard without a driveshaft
Old Oct 13, 2002 | 06:59 PM
357's Avatar
357
Stratoflattener
I got one word: wow.
Old Oct 13, 2002 | 07:09 PM
S2-13BT's Avatar
Did I ever mention you have a very nice steering wheel?
Oh, and the whole thing is looking real nice. I bet you can't wait to drive it.
MIKE-P-28's Avatar
Re: Re: Project Kramer update with Pics!
**** look at his mods, I mean damn, wont be hard anyways, unless I shifter madder quick yo
Old Oct 13, 2002 | 07:16 PM
setzep's Avatar
Re: Re: Re: Project Kramer update with Pics!
If you shift madder quick yo then your driveshat will break madd faster yo!
Old Oct 13, 2002 | 07:23 PM
MIKE-P-28's Avatar
Re: Re: Re: Re: Project Kramer update with Pics!
At least I have driven my car this week LOL
Old Oct 13, 2002 | 07:26 PM
setzep's Avatar
Re: Re: Re: Re: Re: Project Kramer update with Pics!
Damn.... got me there
But then again perfection takes time
Old Oct 13, 2002 | 07:33 PM
MIKE-P-28's Avatar
Re: Re: Re: Re: Re: Re: Project Kramer update with Pics!
I over shot my budget by 2 thousand dollars, and took me 3-4 months longer than expected I made sure every bolt was tight, everything was perfect etc
Driveshaft had nothing to do with me, only 3 things someone else done that was the exhaust, the driveshaft and the turbo.. 2 out of the 3 Im having/had problems with...
Maybe that says somehting?
Old Oct 13, 2002 | 07:35 PM
I am a Jeeper Now.
The large, black intercooler I am using has been proven to have less than .5lb of pressure drop, while having more cooling than many aftermarket intercoolers (Spearco, HKS, Apex'i, etc)
They did arrive, however, they arrived after I mounted the gauges and wired them all in, So I cannot take them out. I will send you a photoshopped pic using the gauges if you like.
Yep, he's right.
It is the large black one, after peeling the paint off with several steps. It is just mounted at an angle. I sold the smaller one I previously had.
Sure did, Great minds think Alike right?
You aren't kidding. The fever is getting at dangerously high levels.
Old Oct 13, 2002 | 07:37 PM
MIKE-P-28's Avatar
I bet you made money on that deal, and in that case I need a finder's fee
Old Oct 13, 2002 | 08:26 PM
very nice. Where did you get the ceter console panel that goes around the radio?
Old Oct 13, 2002 | 08:37 PM
rx7withnos's Avatar
DAMN that looks good : somebodys been REAL REAL busy
Old Oct 13, 2002 | 09:02 PM
I am a Jeeper Now.
Custom Made. More details in this thread here.
Very Busy. However, If it was up to me only, I would work on it 24/7. Responsibilities suck.
Old Oct 13, 2002 | 09:16 PM
diabolical1's Avatar
Ingenuity, Style, Taste ... I know you'll have POWER ... and finally ... Patience ... what can I say?????
Man, I'm totally ******* speechless! Great job thus far ...
Old Oct 13, 2002 | 09:35 PM
I am a Jeeper Now.
Wow, I never expected those kind words, from anybody.
Thanks guys. I am glad I have the forums's seal of approval.
Old Oct 13, 2002 | 09:47 PM
Super Newbie
What, are you like Will Smith in Bad Boys or something? Miami PD and lots of nice expensive ****?
Old Oct 13, 2002 | 09:51 PM
MIKE-P-28's Avatar
I think alex is into selling drugs LOL
Old Oct 13, 2002 | 09:55 PM
mperformance's Avatar
very nice...
