Anyone spun a bearing in a rotary?
Old Oct 12, 2002 | 09:16 PM
Kill No Cone's Avatar
I know it is hard to do, but if you starve a bearings oil supply I know it can be done.
When I hit the gas hard, my enging in makes a chripping noise that is internal . At first I thought it was a detonation or something, but now I thing it my be the rotor hitting the housing or something like that.
Anyone have any thoughts or suggestions?
Old Oct 12, 2002 | 09:39 PM
WackyRotary's Avatar
standard combustion
If you spun a bearing your oil pressure would be very low. Drain your oil and if its got metal flaking in it, if it does, the engine is over, and will need to be apart to repair. Different rotors, and stationary gears with different bearings and probably a different e-shaft.
Old Oct 13, 2002 | 09:03 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
yeah thats exactly what happened to yours
Old Oct 13, 2002 | 09:04 AM
MIKE-P-28's Avatar
By the way I have all of them ... Well the e shaft , 1 rear rotor (perfect) and the statinary gears from a low mileage motor
Old Oct 13, 2002 | 11:35 AM
diabolical1's Avatar
if you really spun a bearing, why wouldn't the motor just lockup?
Old Oct 13, 2002 | 01:07 PM
Jeff20B's Avatar
Lapping = Fapping
I took an engine apart that spun a bearing. Not an easy task because the thrust plate area was all self-welded together!
Old Oct 13, 2002 | 01:17 PM
Rx7carl's Avatar
Airflow is my life
I wiped out my rear rotor bearing at a race earlier this year. It would run and idle, but everytime I gave it gas, it made a loud KNOCK sound, not a chirp. Hows your oil pressure? And do what wacky says, drain and look at your oil, cut open your filter too and look at it.
Old May 22, 2005 | 12:45 PM
2Lucky2tha7's Avatar
Back at it again!!
Bringing this thread back to life
I just spun a rear rotor bearing 2 weeks ago in my 91 N/A. What sucks is that I had only 7,000 miles on the engine!! What's even worse is that I still don't know what caused it!!
Old May 22, 2005 | 05:40 PM
Lt. Dan's Avatar
I've roached two motors that way....
Dan
Old Oct 14, 2005 | 12:24 PM
13BTOY's Avatar
Boosted Fb
Did any of you guys get oil on top of your motor when this happened? I had oil allover the rear rotor.
Thanks, Ed
83revival
Sep 3, 2015 10:42 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
