Need Info on 99 JSpec 17" wheels
Old Oct 11, 2002 | 01:15 PM
gohorns's Avatar
Did not get any hits in the suspension area so I'm trying here. Does any one know the offset and weight for the 17x8 fr and 17x8.5 r 99 wheels. Will the 17x8.5 fit up front? I would like to go 17x8.5 all the way round with 255s. Is that too much tire in the front. I have stock suspension so would the wheel and tire clear the front or will they rub? What do think of that setup?
Thanks
Old Oct 11, 2002 | 03:43 PM
phlanigan's Avatar
I think laujesse had a set for sale; you might ask him for the weight/offset of the 99s.
You shouldn't have a problem with 255s up front. I have 255/35/18s and no rubbing all around. I think a 255/40/17 would fit well. There's a bunch of threads comparing aftermarket to stock wheel diameter.
Old Oct 12, 2002 | 04:29 PM
gohorns's Avatar
Old Oct 12, 2002 | 06:09 PM
JspecFD's Avatar
Did you try searching? Found this thread and I know I've seen others:
99 wheel thread
Old Oct 12, 2002 | 06:35 PM
gohorns's Avatar
thanks for the link JspecFD
I know the weight now but I also want to know if the 17x8.5 rear wheels will fit up front fo I can run all 4 same wheels. If someone know the offset on these that will be of great help.
cristoDathird
28
May 30, 2019 08:47 PM
ChrisRX8PR
Aug 21, 2015 01:56 PM
