adapters for bolt pattern
Old Oct 9, 2002 | 07:06 PM
a1670's Avatar
anybody ever heard of this adapters to convert to a more common bolt pattern? A wheel salesman recommended them but couldn't give me any more details
Old Oct 9, 2002 | 07:10 PM
EL PAALO's Avatar
They work but cost alot for quality units. They also add to bearing wear because it pushes the center of mass further from the hub. The price of good ones + wheels in a common bolt pattern will equal the price of quality wheels in the 4x110 pattern (Panasport, RS Watanabe, SSR, etc.). I'm sure you could get a set of ROH Snyper's or Relex's for less. Not a good idea, imho.
Old Oct 9, 2002 | 07:12 PM
Manntis's Avatar
add to cart
here's the details: such 'adapters' are recommended for show cars only, ones pushed onto and off of trailers and never driven - ever.
Bolt pattern adapters drastically alter your unsprung weight, offset, etc. and can set up nasty vibration harmonics.
In short, they can lead to loss of car or loss of life.
Find wheels that fit your car, or swap the hubs and rear end for those of a GSL-SE. Don't dick around with dangerous 'mods' in the name of looks.
Old Oct 9, 2002 | 07:28 PM
a1670's Avatar
thanks for the feedback guys!!! What does it take to swap to SE hubs?
Old Oct 9, 2002 | 07:31 PM
a1670's Avatar
you guys have a website for ROH,RS WAtanabe, SSR, etc????
Old Oct 9, 2002 | 08:33 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
Nothing just get the complete suspension, front (left and right) and the complete rear axle
and a lot of work
Old Oct 10, 2002 | 12:50 AM
rerun100's Avatar
If you swap out to the -SE suspension and brakes, don't forget to get the -SE brake master cylinder. The proportioning valve is different. It doesn't really matter in around the town driving, but if you really run it hard (or at the track) it will matter.
Old Oct 10, 2002 | 01:55 AM
DriftinJim's Avatar
I've seen theese things run close to $500. they are really a hack and cause undue stress on parts. Find an SE and rob the susp.
Old Oct 10, 2002 | 03:45 PM
As far as the SE gear goes, is it that much better than teh GS stuff that is on my 83? I just put new struts all around and I'd hope to be able to use that stuff too...
S
Old Oct 10, 2002 | 03:50 PM
rx7gslse's Avatar
EX Pres of DFW Drunks
the strust are the same... it's the spindles brake disks in the front and the disk brakes and LSD in the rear that are the big difference...
Old Oct 10, 2002 | 08:13 PM
EL PAALO's Avatar
My sig shows a site with links to those wheel manufacturer's websites.
I also have se hubs lying around.
I like having swappability with our other cars, all non SE's, so I'll probably never use them.
cewrx7r1
15
Aug 6, 2018 11:41 AM
toplessFC3Sman
Mar 20, 2018 01:54 PM
