abs pump fittings
Old Oct 8, 2002 | 11:27 AM
1RedR1and1RedPEP's Avatar
abs pump fittings
can anyone tell me the size of the 3 banjo fittings at the top of the abs pump? I plan on changing them out with bleedable banjos to better bleed the dual master cyl system. I need the lenght, thread pitch and diameter of all three bolts.2 appear to be the same and one looks a bit longer. Id take mine off and measure them but im out of town, and will be at the vendor of the new fittings on thursday nite. thanks all.
1R1
Old Oct 11, 2002 | 03:30 PM
DaleClark's Avatar
RX-7 Bad Ass
I would imagine they would be similar to the fittings on either the front or rear calipers - Mazda doesn't reinvent the wheel that much.
Heck, just get some Speedbleeders at Pep Boys that match 'em!
Dale
Old Oct 15, 2002 | 07:33 PM
thanks, but i either didnt explain this right or you misread. i have since figured this out. I swapped out the banjo BOLTS with bleedable bolts that should help with the bleeding of a dual master cyl. they are 10mmx1.0 pitch
