20b NA?
Old Oct 7, 2002 | 11:26 PM
MazdaRx7Racer4Life's Avatar
I AM A THIEF!! READ THE FEEDBACK SECTION!
20b NA?
can it be done? Would there be a big increase from a 13b na to a 20b na, how many ports does it have, give me the specs someone.
Old Oct 8, 2002 | 01:00 AM
inukai's Avatar
Hi
RE-A is now producing 20B NA motor for a race car.
I will post pics later.
Old Oct 8, 2002 | 01:25 AM
Dyre's Avatar
Your Opinion is Wrong
You're going to spend just as more money that you would just running the stock twin, and make a whole lot let power.
Figure 10k plus to do it.
Old Oct 8, 2002 | 02:37 AM
NZConvertible's Avatar
I'm a boost creep...
Re: 20b NA?
Originally posted by MazdaRx7Racer4Life
can it be done?
Yes, there are a few running around over here. It's no harder than de-turboing any other engine.
Around 50% more than a 4-port 13B. Figure ~200hp.
Two side inlet ports and one peripheral exhaust port per rotor, just like all 4-port 13B's. Mazda never made NA 20B's, so there are no factory specs.
Like Dyre said, you're not going to save much money running without the turbos, you'll just have a lot less power and torque. Even on mild (read safe) boost, the twins will give you 300+hp and more torque than a 300hp 13BT.
Old Oct 8, 2002 | 02:34 PM
vaughnc's Avatar
knowledge junkie
How would you re-tune the 20B for more NA low end torque anyway? VDI, 6port (err 9 port ??), smaller exhaust ports, etc..
I'm assuming you'd want to swap out for higher compression rotors out of the NA engine.
Old Oct 8, 2002 | 04:23 PM
$150FC's Avatar
Currently Winning
no it wouldn't be nine port, the ports is per rotor bah argh >
Duc852
Sep 22, 2015 03:49 AM
