20psi? Should I or shouldn't I?
Old Oct 7, 2002 | 07:58 PM
1FastT2's Avatar
Right now im running about 15psi without any prolbems. I my fastest time with this was an 11.81 so far with little practice at the strip in 85deg weather. There is an import event coming up at Maple Grove in two weeks and I was thinking of cranking her up to around 20psi. I just got my wideband for tuning. Should I risk it or not? Any recommendations where I should have my timing? Right now its at 17degs. I was thinking of setting it at about 12 for 20psi, will this be safe? I would really like to see some real low 11's
Thanks for any input.
Brian
Old Oct 7, 2002 | 08:29 PM
RICE RACING's Avatar
Go for it !
With aviation gas, it will handle it.
I cannot comment on your pump fuel as I am in Australia
12 Deg advance is what I run at that boost.
Old Oct 7, 2002 | 09:52 PM
j9fd3s's Avatar
Community Builder
dumb question: my timing increases under boost with rpms.
would it be better to have it timing vs load, or timing vs rpms?
mike
Old Oct 8, 2002 | 10:38 AM
nocab72's Avatar
03 Cobra Killer
damn dude, that is some serious gear slammin, 11.81 @ 115! I only managed a 12.2 @ 114 this weekend, abeit it was my first time @ the track.
I also have a 10.99 goal for this season. Tuning + new large street ported engine here this week (fingers crossed) + more boost and I should make it!
K
Old Oct 8, 2002 | 04:21 PM
1FastT2's Avatar
K
Hell yea, I shift mad quick yo. Im accually really weary about running 20psi, ill be so pissed if something goes wrong but I guess I'll never know until I try it. Good luck with the new engine.
Old Oct 8, 2002 | 06:59 PM
RETed's Avatar
Both, it should be a 3D map.
But timing versus load would be safer - how do you tell a 7,000RPM decel versus 7,000 @ 20psi?
-Ted
Old Oct 8, 2002 | 09:17 PM
j9fd3s's Avatar
Community Builder
lemme try that again. my timing at 3500 rpms and 10psi is like 5btdc (not actual #s) at 10psi and 7k rpms its more like 12degrees. should i have it at say 12degrees at 10 psi from 3500-7000rpms? or should it slowly advace with rpms?
mike
Old Oct 8, 2002 | 09:22 PM
nocab72's Avatar
03 Cobra Killer
It should begin advancing after you pass the RPM which you make peak torque.
K
Old Oct 8, 2002 | 09:52 PM
j9fd3s's Avatar
Community Builder
gotcha, thanks
mike
Old Oct 8, 2002 | 10:30 PM
nocab72's Avatar
03 Cobra Killer
BTW: My reasoning for this is your highest potential detonation point is at peak torque, ie that is why you see everyone blowing their engines @ mid rpm ranges (5 - 6k) and not from over-revving, etc.
Once you cross the peak torque rpm and are beyond the most likely detonation point you can gradually begin increasing timing...there are significant power gains available by doing this v/s a flat timing setup.
K
Queppa
Nov 18, 2024 03:47 AM
Glazedham42
May 2, 2022 02:41 PM
Glazedham42
1st Gen Archive
Sep 1, 2015 08:20 PM
