Power FC Stalling problem W/ cool coolant temperature
Old Oct 6, 2002 | 12:45 PM
RICKRX7's Avatar
When I decelerate, pushing in the clutch & brake to stop, the RPM drops fast and sometimes kills the engine. This only happens when the coolant temperature is 60C-70C ish.. This Problem started when I installed the PFC. I wished the PFC to self learn and adjust fuel or something but it has been a year and no change. Any ideas?
Thanks
Rick
Old Oct 8, 2002 | 11:16 AM
grampa's Avatar
If you have the commander or datalogit you could try upping the water temp correction in the +50o range.
I had the same problem with it running lean during warmup, upping the water temp corrections fixed it.
Old Oct 8, 2002 | 06:33 PM
RICKRX7's Avatar
OK,I have read the instructions for "water temp correction" but I am not sure how much fuel to add to the left or right #. What did you do? BTW I have the commander.
Thanks
Rick
Old Oct 10, 2002 | 10:22 AM
nocab72's Avatar
03 Cobra Killer
Without a Wideband you can't know for sure if a rich or lean condition is causing your stall problem. If you want to play w/out a WB, make small changes (less than 5%) and see if your problem gets better or worse, if worse, try 5% the other way, if better try another couple % until it stops.
K
Old Oct 11, 2002 | 06:23 PM
RICKRX7's Avatar
K
I will try the under 5% adjustments. Do I start with the heavy load, light load, or both?
Thanks
Rick
Old Oct 10, 2005 | 11:14 PM
Gouki7's Avatar
sorry to bring this thing back, but I'm having the same issues. How many degrees did you move it? I changed it from (I believe) 108-110 and 102-104
Old Oct 11, 2005 | 12:22 AM
Matt Hey's Avatar
Old School
I can't help answer your question but I can suggest a couple of things that may help...
In Setting 4 'IGN vs WaterT Cool' change the retard at 60 Temp from 15 to 5.
Try new spark plugs.
Old Oct 11, 2005 | 01:42 PM
Gouki7's Avatar
I changed the 50 degrees celesius area sorry for the confusion. So I should change that also? at the 60 temp. I'll try that
troym55
23
May 25, 2016 12:42 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
