Clutch noise at startup- Plz help
Old Oct 5, 2002 | 02:40 PM
waiata's Avatar
Question Clutch noise at startup- Plz help
When starting up cold, and when the clutch is pressed, my '86 is making a sound like a buzzsaw sawing wood. After it has been driven for a couple minutes, the sound no longer occurs when the clutch is pressed.
Obviously, transmission-based... has anyone else experienced this and how major is it??? Or is it something simple?
Thanks for your help!
-Gary
'86 138k
Old Oct 5, 2002 | 06:31 PM
Rxmfn7's Avatar
Do a barrel roll!
Its probably a bad bearing....Id say the pilot bearing.
Old Oct 5, 2002 | 07:08 PM
waiata's Avatar
Thanks!
I'm thinking a bearing as well now. Either throwout or pilot.
No noise when clutch is not pressed, only noise when clutch is pressed.
Old Oct 9, 2002 | 11:48 AM
fcouperus's Avatar
I'd head for the throw out bearing. Although it's sealed and self lubed, more prone to dryout and lock due to ambient heat.
A bad pilot bearing would start to bind the tranny mainshaft (input shaft) keeping the main shaft at Eccentric shaft RPMs with the clutch depressed. This in turn effects synchro in the gear box and makes 1st/Rev gear shifting hard. You'd hear it all the time too since its a non load effected bearing.
So if shifting is okay head for the throwout
Hope this helps
The1Sun
Sep 18, 2015 07:13 PM
83revival
Sep 3, 2015 10:42 PM
