Installing Greddy Profec B...
Old Oct 4, 2002 | 07:02 PM
Scrub's Avatar
bow leggin'
Question Installing Greddy Profec B...
On a stock Rx-7 where can i mount the brain to the unit under the hood. I can't find a place to mount it. Also is the installation hard? Any help would be greatly appriciated.
Old Oct 4, 2002 | 10:56 PM
Chaz's Avatar
Try checking out the following site:
http://www.alltrac.net/manuals/GreddyProfecB.html
Hope this helps answer some of your questions. I'm afraid I can't help much more than that cause I haven't received the one I've ordered. Good luck!
Old Oct 5, 2002 | 03:22 AM
GsrSol's Avatar
Z06 powered FD
I can't find the pic but I put mine on the passenger side strut tower (closer to the windshield), next to the ABS unit, and directly under a big blue plug. Confused yet?
Old Oct 5, 2002 | 07:55 AM
evot23's Avatar
Classy
There is also a spot by the passenger headlight. Its tight but it will fit there.
Old Oct 5, 2002 | 08:04 AM
Scrub's Avatar
bow leggin'
Thanks, ill check it out.
Old Oct 5, 2002 | 08:31 AM
evot23's Avatar
Classy
Here's where GRSOL was talking about.
Old Nov 3, 2002 | 03:15 PM
coop's Avatar
How do you know when to use the 'over boost' setting on the Profec?
I am still getting 10psi with the all the settings turned down to min. Is it time to use the 'actuator overboost' setting?
Old Nov 3, 2002 | 05:58 PM
Read this link 10-1 you didn't remove the hose from the backside of the wastegate actuator. Leave the precontrol lines with pill in the stock configuration. Step by step instructions on the link below. If you don't take the other line off the wastegate controller (backside)boost will stay at 10 even with the profec off.
https://www.rx7club.com/forum/showth...ghlight=profec
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
