87 TII helped needed!
Old Oct 4, 2002 | 04:14 PM
HI,
I have a 87 TII with a problem
The car has no power at all. Will not go over 45mph! Whenever i hit the gas it just makes a chattering noise (not from engine) the turbo is boosting and the car is making power, just not making it to rear wheels.
ANy ideas?
Thanks
Old Oct 4, 2002 | 05:15 PM
NRA T2's Avatar
check your drive train, and make sure your E brake isn't on
It's possible a caliper is locked up or some thing, I don't know, maybe your diff is shredded
Old Oct 4, 2002 | 05:23 PM
biorotary's Avatar
if the noise is not from the engine, then where from?
Old Oct 4, 2002 | 05:25 PM
Pinfield357's Avatar
yeah check the rest of the drive tran ne smells coming from around the wheels (a draging brake)
Old Oct 4, 2002 | 05:32 PM
NRA T2's Avatar
you could jack up the rear end off the ground and start it and put it in gear, check where it's coming from that way ( wouldn't recomend if you don't work on cars and know what you're doing or you could end up with an rx in a garage door or something)
Old Oct 4, 2002 | 07:57 PM
Could it be a severly worn clutch and pressure plate?
Thanks
Old Oct 4, 2002 | 08:02 PM
Rs4Racer's Avatar
DONT PUT IT UP ON JACKSTANDS AND START IT AND PUT IT IN GEAR!!!!
thats the stuipidist suggestion i ever heard.
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
