dynamat
Old Oct 3, 2002 | 04:47 PM
suganuma's Avatar
no
dynamat
how heavy is this stuff??
work well??
Old Oct 3, 2002 | 05:20 PM
darkside7's Avatar
Depends on the dynamat you get. There like 5 different kinds made by them. The originals are not that bad, as long as you don't put on too much.
Old Oct 3, 2002 | 08:21 PM
I bought some sound matting, you will have some trouble keeping it on your trunk. Make sure you use spray glue to keep it on or it will be falling out in pieces shortly. It isnt too heavy, less than 20 pounds for 60 square feet. It makes a difference around trouble spots. Mat your license plate with a layer or 2, and put it behind the bolts that hold in your tail lights. Significantly reduces external rattle and all the internal.
Old Oct 3, 2002 | 08:36 PM
suganuma's Avatar
no
that sounds kinda heavy....
guess i'll just keep it loud for now
Old Oct 4, 2002 | 01:33 PM
rynberg's Avatar
don't pay the money for the dynamat...
just get any "mass-loaded vinyl" product made by dozens of companies, the most common densities are 1/2 and 1 lb/square foot. The 1/2 would probably be adequate for trying to reduce noise in an FD as you can only go so far
Old Oct 4, 2002 | 02:24 PM
suganuma's Avatar
no
what has best effectiveness to weight ratio?
Old Oct 4, 2002 | 03:05 PM
rynberg's Avatar
I think for the application of trying to quiet an FD down, the 0.5 lb/sq ft would be just fine. Obviously, the 1 lb/sq ft will be more effective but you start hitting a wall. Sound transmission through the windows, door/sunroof seals, firewall, and just general overall structure-borne noise that the treatment won't stop.
You might want to try a mixed approach, although you will be adding a bunch of weight either way. Something like:
*use 1 lb/sq ft for the hatch bottom/spare tire well
*use 0.5 lb for doors, and side walls
*use 1 lb for floor beneath carpeting
These are just guesses as I have never extensively measured the inside of the car. Maybe I will make that a project one of these days.....
Old Oct 4, 2002 | 05:10 PM
suganuma's Avatar
no
on one hand i say, i can add a little more weight and make the car a little "nicer" inside......i.e. be able to hear someone if they call the cell phone and them hear me, etc
and that would be ok with the additional power....
another side wants to go rip everything out....
and another side thinks that even if i do this project, one day the "make it lighter at all costs" side will win over and then i will have to go back and rip all this **** out....
decisions decisions.....
this stuff you're talking about is the most effective stuff or the lightest stuff??
Old Oct 4, 2002 | 10:09 PM
Icemark's Avatar
remember you are only adding a little less weight than the sheet or box of the vibration reducer.
So if you get a 10 lbs box and use all that, you have only added a little less than 10lbs
Old Oct 5, 2002 | 05:19 PM
suganuma's Avatar
no
nic realizes this.....its still 10 lbs
-Nic
Old Oct 5, 2002 | 06:22 PM
all i can say is dont use E-Dead!!!!!!!!! it sux so bad!!!! it wont stick to any thing you put it on and it pells off no matter what you do to it!!!!! AAAAAAAAHHHHHHH!!! sry about that i just had to get that out of my system
Old Oct 5, 2002 | 08:30 PM
Icemark's Avatar
well the big key with any sound deading material is to make sure the surface is very clean before appling.
You should swab and wipe the whole area down with acetone before applying anything like dynamat or e-dead of any other sound deading material.
Old Oct 18, 2002 | 12:10 PM
He was referring to my car. I cleaned the area before i applied it. I used a blow drier to heat it up after the first time failed. The blow dried layer fell off in 12 hours. I then tried super 77 spray glue, and it had the same result. E-dead is crap. Dont buy it.
Old Oct 19, 2002 | 06:11 PM
RonKMiller's Avatar
Blow up or win
Use Super 90 instead. I know it's $20 a can. It will make an ice cube stick to teflon.
Spray both surfaces VERY LIGHTLY, less is more. Let it tack up for 5 minutes. It's on forever.
justinpace
13
Feb 26, 2009 09:39 AM
pianoprodigy
Interior / Exterior / Audio
Jan 20, 2003 09:45 AM
Jetlag
Jan 11, 2003 09:31 PM
