Is this possible?
Old Sep 26, 2002 | 02:43 PM
big_sur's Avatar
Question Is this possible?
Is it even possible for a car to be running with 5-7psi compression on all 3 sides?
Old Sep 26, 2002 | 02:50 PM
blackscorpio's Avatar
#1 F0RUM TROLL
yes it possible but not likely, a motor runnin 5-7 psi would be shot to ****.
Old Sep 26, 2002 | 04:29 PM
rynberg's Avatar
considering a spec motor should be at 100 psi or greater, I don't think a motor with 7 psi on all three faces would run. I think you are getting psi units mixed up with kg/cm^2, which should be 7 or higher.
Old Sep 26, 2002 | 04:55 PM
big_sur's Avatar
thats what i said after i thought about it for a minute so i called back mazcare(they were checking out a car for me) and they said 7 psi and front end damage basically the car was a rolling piece of ****, this after the owner said it had a brand new engine no accidents\problems. go to show you some people
