What do I need to run 10's?
Old Sep 19, 2002 | 11:55 PM
WhiteRx7's Avatar
I know it's dependent on driver skills, but I want to know what I need to do to at least have the potential to run 10's with my 88 t2. Any suggestions would greatly be appreciated!
Old Sep 20, 2002 | 12:18 AM
presetlimits's Avatar
whens the last time you watched F&F?
Old Sep 20, 2002 | 12:29 AM
Kai's Avatar
Kai
Rotorphile.
If you have to ask... you can't afford it.
Completely strip out the car, swap in a 20B, then port and turbo the **** out of it. Virtually everything in or on the car should be an aftermarket performance part. Plus some nice slicks. Say, $30k and a really, really good mechanic. That should do it.
BTW, it will not be streetable. "For offroad use only."
Good luck!
Old Sep 20, 2002 | 12:37 AM
DC350's Avatar
Rotor Head
1fastt2, his next goal is 10.99 and soul assasains car, runs under 10.....20b? my ***. And it will be streetable, upgraded turbo, big injectors, new fuel pump, engine management computer, full exhaust, your on your way!
Old Sep 20, 2002 | 12:41 AM
FC Drifter's Avatar
Damaged Little F*cker
money...a big fat wad of it. youre looking at stand-alone ECU, BIG turbo, and some engine work like at the very least a big street port. 3mm seals couldnt hurt either. plus some supporting mods too. youll need lots of fuel, a bad-boy clutch, slicks, and whatever is neccesary to make your car NHRA saftey regulation legal, like a roll cage.
Old Sep 20, 2002 | 12:43 AM
Kai's Avatar
Kai
Rotorphile.
I was just kidding, a 20b is not nessicary, it's just that he makes it sound so easy... and it's not. BTW, it would not be streetable in here in VA, any car that you can refer to as "modded" and "rotary" within the same sentance would most likely fail emmissions here.
AggieDave's Avatar
you can run a 10 on a large turbo, lots of boost and juice
but i agree with Kai. If you have to ask you prolly cant afford it. you are looking at 12,000+
dave
87 TII (Series V Conversion)
Old Sep 20, 2002 | 12:45 AM
BrainFood's Avatar
What about 11's in a 2000lb fc (dont ask it isnt really ) and no worries about emmisions, can it be done on a turbo that doesnt have massive lag on a 13b?
Old Sep 20, 2002 | 12:48 AM
HWO's Avatar
HWO
inteligent extratarestril
you need to aim for 450+ Hp at the flywheel
Full T04 turbo with a 60-1 compressor or bigger
Aftermarket exhuast manifold
External Wastegate
Fuel Pump
4 x 800 cc injectors or stock primarys and 1600cc secondarys
FPR
Fuel pump
Haltech E6K or similar stand alone efi system
3 inch exhuast
FMIC or Water to Air IC
drag radials or slicks
a fair amount of weigh reduction
A GOOD clutch
that should see you into the ball park
Old Sep 20, 2002 | 12:52 AM
BoostedRotors's Avatar
I HATE sleepy eyes
I dont think people fully comprehend how damn fast a 10 second car is!
Old Sep 20, 2002 | 12:53 AM
FC Drifter's Avatar
yes it can. a friend of mines old T2 had a t60-1 on it and it made a full 15psi of boost at 3500rpm, so it wasnt that laggy. rotaries have the benifit of extremely hot and fast exhaust pulses that lead to quick spooling. this allows us to run big turbos with minimal lag. 11s is not a far-fetched goal for an FC with the right work done to it.
Old Sep 20, 2002 | 12:58 AM
bingoboy's Avatar
Lava Surfer
Firstly, go to Lingenfelters web page and find the 427TT setup and click on "Add to Cart." Next go to "Checkout" and be sure to have a major credit card available!
Old Sep 20, 2002 | 01:20 AM
HIMNI Racing's Avatar
Rick James
Is F&F out on dvd now?? i've always said that if u don't know how to make the power... you shouldn't try to control it either. I't just suicide! Good Luck.
Old Sep 20, 2002 | 01:42 AM
BrainFood's Avatar
To give you an idea of what 10 seconds cost on other cars (see sig) I have a full built motor in my 3000gt, heads, cams, everything pretty much.... I have been waiting on a couple of stand alones but when I do fuel and buy even bigger turbos I will spend another $8k+ on that, plus the $12k I have spent on my motor and some support and another $3k in bolt ons. this is all with no labor charges since I do all my own work (only labor included was machine shop work) so that is $23k in parts and the car will run low 11's high 10's, this is will be daily driven though so there is a difference, this run wont be made on big ole' slicks since the awd hooks up good. But that gives you an idea of what it takes. add labor and that is easily $33k into the car. Fair this is also 1000lb's heavier than an FC and awd but 10's are insanely fast, believe me if you can drive a car that is fully streetable that pulls high 12's you wont loose on the street, at least I dont.
That's good to know my 510 will have a rotary conversion and in a year or 2 will also get a built 13b with street porting and a nice turbo setup and it will wiegh about 2000-2150 around there so with some big slicks slap'd under there I will expect some nice 12 second runs then!!
Old Sep 20, 2002 | 04:13 AM
Rs4Racer's Avatar
my fc is about 2k lbs.
but im missing some parts. ie engine, tranny, front bumper fenders and hood, rear bumper, radiator, all of the ac, all rear interrior gone.... ect....
Old Sep 20, 2002 | 09:00 AM
ptrhahn's Avatar
Just do the "10's" mod. Adds 500 hp.
Old Sep 20, 2002 | 09:21 AM
BogusFile's Avatar
Takes alot more than money to run 10's reliably.
Old Sep 20, 2002 | 09:49 AM
RylAssassin's Avatar
I own a Skyline and ive invested over 60k to make it a 10 sec car. Ive upgraded the turbo, intercooler, exaust, suspension, lots of engine work, lots of weight reduction, brakes. The best time ive gotten on 1/4 so far is 10.210, And thats with over 600hp at the wheels. Ive raced so many cars with it and beaten so many races that i cant imagine anything faster than my skyline. Ive made probably a good 100 grand off my wins. SO having a 10sec car is easy if your like me and can spend lots of time winning races in gt3... Oh wait did i mention that this was my car in gt3 yet? Woops
Old Sep 20, 2002 | 10:16 AM
8 pistons
Probably not the best way, but I bet it is the cheapest way...
Go to your local dirt track, best to go near the end of the season.
Find a 406 chevy with aftermarket heads (Brodix or AFR)
Used this engine should be less that $3500 complete.
TCI TH350 with 3000 RPM converter $1800 (or less used)
NOS-Big Shot $500
This combination runs 9.90's in a 72 Chevy Nova (3500 lb) on the bottle, 10.90's on the motor.
Old Sep 20, 2002 | 10:23 AM
cafcwest's Avatar
Kai,
You said you were were worried about emissions here in VA. They only test up in NoVA. Just drive down to Fredericksburg or Richmond and get your car inspected. :-)
Old Sep 20, 2002 | 11:16 AM
Josepi's Avatar
Despise Enmity
Originally posted by cafcwest
Kai,
Yup...no *** probes for miles.
Old Sep 20, 2002 | 11:35 AM
Snrub's Avatar
See the banner at the top where it says "featured car."
Old Sep 20, 2002 | 12:04 PM
WhiteRx7's Avatar
Thanks all, for the info.
Here's the mods that I have on the car,
rb turbo back exhaust
greddy td06sh 20g
greddy fmic
greddy type s bov
2 720 secondaries
2 550 additional
safc
avcr
upgraded fuel pump
fuel pressure regulator
new act street/strip clutch
I'm suppose to get somewhere between 400-450hp at the crank. what kind of times am I looking to get? I'm almost done with the install, just have to hook up the electronics and weld the blow off valve but have no time to spare.
Old Sep 20, 2002 | 12:19 PM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
High 11's probably.
Brad
Old Sep 20, 2002 | 03:39 PM
Funklord's Avatar
heres a plan to get you into the 10's. get an eclipse and drive it at 140mph towards a cliff. that will make you realize you need NOSSSSSS. then get a BIG bottle, no wait TWO of them! then race people and spray ALL YOUR NOSSSSSSS until your computer says danger to manifold and you're going so MADDD fast that your floorboard cant take it anymore and falls off (???) then you're in the 10's.
