Removed AWS Valve
Old Sep 18, 2002 | 03:30 PM
cblake3's Avatar
Removed AWS Valve
Last week I removed my Accelerated Warm-up Solenoid valve and capped off the nipples on the BAC and Intercooler. I disabled the accellerated warmup cycle years ago.
I don't know if this is related or not, but now when I turn on the headlights, the car runs real rough. Wants to die when I apply the brakes.
In fact I can get the car to die by pumping the brakes w/o the headlights on.
You guys think that this is related?
The car idles like a champ without touching the headlights or brakes.
Do you think that running a vac line connecting the 2 nipples between the intercooler and the BAC would help.
My thought is that the BAC is starving for air or somthing now.
Old Sep 18, 2002 | 03:32 PM
HAILERS's Avatar
HAILERS
Sounds like you killed the bac's air supply.
Old Sep 18, 2002 | 03:44 PM
cblake3's Avatar
Should I run a vac line like I said??
Old Sep 18, 2002 | 04:21 PM
vmb
do it and see if your problem goes away!
Old Sep 18, 2002 | 04:24 PM
Scott 89t2's Avatar
SOLD THE RX-7!
??? the BAC and AWS do not even touch each other. the AWS line goes from the manifold to the IC. block both of those off, don't touch the BAC.
edit: unless it's different on S4....
Old Sep 18, 2002 | 04:34 PM
cblake3's Avatar
The S4 must be different. The lines from the AWS go from the intercooler.....to the AWS...to the BAC.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
