Don't want to shoot flames.
Old Sep 18, 2002 | 03:30 AM
dag's Avatar
dag
Hey all, I've got an '88 turbo 2 and I'm finally going to start modding the power side of it. I was wondering, if I were to strap on a racing beat turbo back, would I shoot flames? I ask because I don't want to shoot flames (at all) as being in california I'd like to draw as little attention to emissions as possible, if I will shoot flames with the RB system is there any way to remedy that short of strapping a cat in? Thanks.
dag
Old Sep 18, 2002 | 03:48 AM
NRA T2's Avatar
if youm don't put on a down pipe leaveing on the pre cat you shouldn't
Old Sep 18, 2002 | 12:55 PM
Sammymatik's Avatar
Hi, my little bro is usning my exahust right now. WHIch is just a straight pipe from the manifold, he's also got a K&N filter, but his doesn't shoot flames (From an NA motor). When I put this exhaust back on my car, TII that is streetported, will I get flames ya think? I live in CA and I hope I do!
Old Sep 18, 2002 | 12:56 PM
Turbo II FC's Avatar
Total Balance is Key
Im pretty sure you will get flames every now and then. I get flames from just driving regular all the time just look at my avatar.
Old Sep 18, 2002 | 12:58 PM
MtnRacer's Avatar
infini guru
If you have any sort of catalytic converter on the car, it won't spit fire. My advice would be a downpipe, a hi-flow cat, and the cat back. You'll be fine with a quieter, flame-free exhaust, that won't be robbing you of too much power. =)
Steve
P.S. It helps the environment too!
Old Sep 18, 2002 | 01:45 PM
darkwaveboi's Avatar
Need donor car in Fairfax
If you take out the main cat, you WILL shoot flames mostly during 3rd gear redlining.
If you get an atmospheric BOV, then the chances of shooting flames are even greater. but yes..as said above, if you have a main cat on the car you wont shoot no flames
Drakk0r's Avatar
If you get a timming controller and a fuel controller you can tune it to make more power, which will also prevent you from shooting flames... Or you can just turn down your boost a bit and advance the timming on the CAS. Shooting flames are caused by the ECU retarding the timming to far when you let off the throttle which basically sprays fuel into the exhaust.
Old Sep 18, 2002 | 01:51 PM
Ni5mo180SX's Avatar
White Comet
My NA doesnt shoot flames with a straight pipe from the manifold back, but then again I think I have a couple exhaust leaks
4X4CrewDu
Aug 24, 2015 08:44 AM
