help
Old Sep 13, 2002 | 08:31 PM
Newbie
help
hi!the fuel line underneath manifold lid take manifold out change the new fuel line and put it back and i start ithe engine it sound not normal i don't know what happen,so any experience on that please help?thank alot
Old Sep 13, 2002 | 08:50 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Huh? is it just me or this this hard to concept. he he
Sorry me no be able to help.
qeu?
Old Sep 13, 2002 | 08:53 PM
rxrotary2_7's Avatar
ummm...i to no understand you type. but i think your problem would be you have to prime the fuel pump. you can do this through the diagnostic box.
Old Sep 13, 2002 | 08:56 PM
rxshun7's Avatar
translation: Hi. I'm having a problem concerning the fuel line under the manifold lid. I took the manifold out to change the fuel line. After replacing the manifold and starting the engine, I noticed that my car didn't sound normal. I don't know what happened. If anyone has experience with this could you please help me. thanks a lot.
geez its not that hard to understand guys. phuong next time you should try to use complete sentences so that people can understand what you're saying without having to translate.
Old Sep 13, 2002 | 10:42 PM
ahahahah fun very, much funny
Old Sep 13, 2002 | 10:50 PM
spooledUP7's Avatar
There and back again
He did use a (?)
Old Sep 14, 2002 | 12:19 AM
hapa's Avatar
Phuong, check your MAP sensor. It's the small black box on the driver's side firewall. It has a small hose that get's knocked off easily and causes your idle to bounce and run terribly. Check that first, also make sure you primed your Fuel lines before starting the car.
eric
Old Sep 14, 2002 | 07:04 AM
me drive, very much good! car no run very much bad.
yeah, check the map sensor.
Old Sep 18, 2002 | 02:47 AM
Newbie
you all thank you 4 advise. That not the problem, I found the with the spark plug wire. See u again on my next post.
Old Sep 18, 2002 | 10:45 AM
JONSKI's Avatar
5yr member, joined 2001
Couldn't we just help him out without criticizing his english?
