Sponsored by: CARiD
Need Help...QUICK !
Old Sep 13, 2002 | 02:15 PM
Roy Johnson Jr's Avatar
Boost Feels Good
Need Help...QUICK !
I've got my car at the dyno to be tuned. Here's the problem:
MAIN PROBLEM
When the car is cold, it will start right up. But, if you let the car run a little bit and warm up and turn it off, it won't start until it cools down
What should we be checking? My tuner said that the spark coming from the plug wires is more yellow than blue.
MINOR PROBLEM
It's getting plenty of fuel - in fact, at idle it is pushing 75 - and we can't get that number to come down at all. He was wanting to get it around 45. What should we check here? I've got Ray's big pump pushing through -6 lines. Regulator is SX brand.
Thanks for the quick replies as I'm paying for dyno time as you are reading this
mY MODS ARE:
Greddy T-78 Single Turbo
Large Streetport / Dowel Pinned / 3 mm Seals
Greddy Down Pipe
SR Motorsports Resonated Mid Pipe
Apexi N1 Dual Tip Cat-Back
Greddy Type-R Blowoff Valve
Unorthodox Pulleys
Greddy Elbow
Greddy 3 Core Front Mount Intercooler
ACT 40% Over Clutch
Shane Racing 9.5# Aluminum Flywheel
Stainless Steel Braided Brake Lines
SR Motorsports Ultimate Fuel Pump
-6 Braided Fuel Lines
Weldon Racing Fuel Filter
SX Rising Rate Fuel Pressure Regulator
Power FC w/ Commander w/ Datalogit Laptop Software
HKS Twin Power Ignition
1600cc Secondary Injectors w/ Custom Fuel Rail
Aquamist Alcohol/Water Injection
Magnecor 10 mm Plug Wires
Old Sep 13, 2002 | 09:49 PM
diabolical1's Avatar
is there any adjustment on your pressure regulator (i know it said it's a rising rate type)?
are you sure the injectors you bought have the right impedance?
check the installation of your HKS ignition ...
sorry that's all i can think of. hopefully, something is useful to you.
