choke problems. .. . .
Old Sep 10, 2002 | 07:20 PM
ugg.. well today i finally got the car idling beautifully.. anyone who doesnt know the story behind the car... i bought an '85 GS for $250, it has a blown transmission and it wouldnt idle when i got it...
today the choke functioned properly / i figured out how to use it...but after 2 uses of the choke, i went to crank it one last time to bask in the glory of success, and the choke just went back in when pulled out... any ideas?
Old Sep 10, 2002 | 07:32 PM
Avenging Angel's Avatar
The choke will only stay out when the engine is cool. after the engine warms up it'll automatically go back in VIA magnetic field. if you turn off the car while its hot, and turn it on again afterwards while it's still warm, the choke will go in cause the engine is already warm enough.
Old Sep 10, 2002 | 07:40 PM
thanks
hmm..when the car starts when its hot it just dies.. it idles for ~10 seconds and flatlines,... :| any suggestions?
edit: when choked it idles at ~1800 RPM ... when hot it TRYS to idle at 800+/- 50 rpm ... is something mis-tuned on my engine? / is my engine going bad ? or is it just screwed up carb?
edit again: oh yeah, when the chokes on and the cars idling it makes nice little explosive noises in the exhaust for about 30 seconds then idles as smooth as silk, revs perfectly and everything...
Old Sep 10, 2002 | 08:26 PM
diabolical1's Avatar
do you have a service manual (FSM, Haynes, Chilton)?
try turning the idle speed screw slightly (maybe 1/4 turn) and see if that's enough. if, and ONLY IF, it starts to do funny things after you turn that screw, then you can adjust the idle mixture.
see if that works, and let us know ...
Old Sep 10, 2002 | 08:31 PM
yeah man, have the haynes manual in front of me.. it seems to be idling at the right speed when it does idle, but it dies as though it runs out of fuel when its not patted if the choke is off..with the choke on, it idles from 2500 down to 1800 then down to 1000 and then it would most likely go down to 750 if i let it idle longer... note: all this is done in neutral since my transmission = dead ! :| anyway, thanks for the help..thats what i was considering earlier but i always like a second opinion since im new to this
Old Sep 10, 2002 | 09:11 PM
can someone do me a HUGE favor and post a picture of the idle speed adjustment screw, ive looked for it and cant seem to find a trace of it, even looking where they show it in the haynes manual ;(
Old Sep 11, 2002 | 06:50 PM
bump.. i still need help :|
Old Sep 11, 2002 | 06:55 PM
Directfreak's Avatar
I am a Jeeper Now.
Get more info HERE
Old Sep 11, 2002 | 08:56 PM
thanks man, appreciate it... i think my carb is missing that screw or something..lol about to douce it in WD40 and see if the screws hiding under some of that oil...
Old Sep 11, 2002 | 11:03 PM
cletus's Avatar
If the screw isn't there, in the mean time you can adjust the idle by playing with the slack in the throttle cable. Not the best way, but it works. Just adjust the nuts that are on the cable.
Old Sep 12, 2002 | 04:52 PM
god, i hate my car ... ugg *flips it off* it cranks now, shoots up to 1000 RPM, idles for 2 seconds, and dies lik,e its not getting any fuel... i think its carb rebuild time
Hipsiguy
Jan 13, 2016 01:08 PM
scissorhands
Oct 8, 2015 01:17 PM
