133-RE Plates on a 13bt?
Old Sep 9, 2002 | 05:18 PM
Has anyone on hear fitted Ft and rear Secondry Plates of a 13b-re to a S5 13bt?
I know the rear plate will fit ok but i dont know about the ft one? i've been told it will fit but i'd like to see it done? will the Cas and oil pump cover fit?
Thanks.
O yeh i did search but could'nt find what i am after.
Old Sep 10, 2002 | 09:38 AM
no one?
Old Sep 10, 2002 | 09:56 AM
DaleClark's Avatar
RX-7 Bad Ass
In theory the front cover should fit - I've heard of 3rd gen guys using the early front covers and mechanical oil metering pump with the Haltech.
The rear iron would be tricky - it has the motor mount holes in it, which are tapped into the oil galleries and would have to be plugged properly to prevent an oil leak. Also, one of the turbo oil feeds or drains is on the rear iron as well.
Oh, this is all in regards to the 3rd gen motor - I have no idea on the Cosmo motor.
Why are you asking?
Dale
Old Sep 10, 2002 | 10:11 AM
banzaitoyota's Avatar
What Subscription?
This sounds like the setup Rob at Pineapple wants me to run on the TII From Hell.
As i have just Bridged a set of Cosmo 13b-re secondry plates and am hoping its all going to fit nicely when it goes together.
Chris
Old Sep 10, 2002 | 10:14 AM
? Turbo 2 from hell?
So has he done it before? as u would not belive the size of the ports on these things, Imagen a street ported Fd secondry! thats stock on a Cosmo. But the Primarys are realy small.
