Does anyone have pics of an HKS TP install?
Old Sep 9, 2002 | 05:13 PM
jpandes's Avatar
Question Does anyone have pics of an HKS TP install?
I just got one from a forum member and I nned a little help installing it. One end of the Wire harness has the connector cut of and I need to know exactly where to connect the wires to my FD.
The exposed HKS TP wires are:
2 Yellow: Trailing coil(s)
1 White: Leading coil
1 Red: Ignition 12 v power source
Where do I connect/splice these wires? I wish the harness wasn't cut.
Where can I see pics???
Old Sep 9, 2002 | 07:27 PM
jpandes's Avatar
Old Sep 9, 2002 | 07:52 PM
Sled Driver's Avatar
The Anti-Prius
www.corksport.com sells the HKS harness adapter for $15 or so.
HKS makes a direct plug in harness so you don't have to cut up your stock harness. If you already cut into it, bummer dude.
Old Sep 10, 2002 | 07:19 PM
The Anti-Prius
Let me get a clear picture. You have the HKS TP with the plastic connector on it, wires are uncut up to this point.
Included was a harness that plugs into the HKS plug, that has just loose wires on the other end. Right?
That is the universal harness that you have to splice into 2nd & 3rd Gen's.
Buy the harness adapter from Cork Sport.....
Now, if the harness from the HKS unit is cut you can still use it, but you wont be able to simply unplug in the future. You'll have to hard wire it in. PM me if you need the Directions on how to hook up each wire.
I would include it now, but IM at work & the directions are at home.
I have an extra universal harness you can have if you, or anyone else, needs it.
rotor_veux
46
Jun 12, 2018 10:39 AM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
