Still can't figure out Auto-Manual Wiring
Old Sep 8, 2002 | 01:44 PM
ejmack1's Avatar
Lawn Ornament
Does anyone have any suggestions? I have everything done except the wiring, i get power on everything but it wont crank when trying to start the car, It will crank if i jump the starter solenoid. Also what sensors NEED to be hooked up in order to start the car...
Old Sep 8, 2002 | 03:21 PM
jbtam99's Avatar
Had a friend with a similar problem, he got it figured out before I could get under my car and figure it out... For all you guys installing haltech's in Automatics, you might want to read this too... might save you some headaches.
Apparently there's still some wiring having to do with the gear position switch, (what allows you to start the car only in P or N) that has to be jumped. If you replaced all the harnesses with the MT ones, this is probably not your problem.
Direct from the mouth of Marcus Williams:
the starter interupt relay is located on the driverside kick panel, unplug it and jump over the two large wires ( i think one is black/white stripe and the other is blue/white stripe) at any rate it is the two large wires.
and then go over to the pass. side kick panel and find the x-05 plug (large blue plug) and jump over the two large wires ( one is red and the other is blue) the only two LARGE wires there. and there ya go the starter works like normal.
Hope this works for you.
John M
Old Sep 8, 2002 | 03:34 PM
ejmack1's Avatar
Lawn Ornament
well, i figured it out, i jumped the Neutral/Park wires on the auto tranny harness and bypassed the clutch switch and it starts right up... well.. it cranks... but wont catch
troym55
23
May 25, 2016 12:42 PM
gxl90rx7
Haltech Forum
Sep 14, 2015 03:09 PM
