boost question...what is the cause of pressure drop at transition on a seq setup??
Old Sep 7, 2002 | 07:56 PM
artguy's Avatar
WTB** Very Low Miles 94-95
hey all
what is the typical cause for a boost pressure drop at transition...say 12-6-14 boost pattern...or a 12-7-15 boost pattern??
I have my own ideas but am wondering if anyone has any good input.
am finally done tuning for a 12-9.5-15 boost pattern and am ready to inch up the boost and retune..however I noticed today that Im getting a pressure drop at transition to around 7psi from 12 primary to 15 secondary.
Im using the manual boost controller and the pfc to control boost until i get the profec b.
both are installed correctly...I have new sensors and actuators.
j
PS...Im also having a problem controlling primary boost...with the precontrol closed and not allowing any prespool I am able to get full boost on the primary turbo...but with the precontrol open enough for prespool I cant boost past 12 lbs.
my goal is a 16-14-16 boost pattern or thereabouts...
the pfc sucks at controlling boost btw. hahah
Old Sep 7, 2002 | 08:28 PM
serge1's Avatar
"what is the typical cause for a boost pressure drop at transition...say 12-6-14 boost pattern...or a 12-7-15 boost pattern??"
-Got the same problem on my 95 FD. Was a Missing restrictor pill in the wastergate actuator line.
Serge
Old Sep 7, 2002 | 08:37 PM
artguy's Avatar
cool..thanks for the info...
any other ideas guys?
Old Sep 8, 2002 | 01:20 AM
racer rx's Avatar
Hi Artguy,
Is your Profec installed into the Pre-control line? Or just the Wastegate line?
If your getting a big drop during the switchover then I think your pre-control pill is the wrong size. I think you might want to add a larger pill in the pre-control line.
However not to large... you might get boost spikes.
I think My pattern is 12.5 - 15 - 14.5. I'm using the Blitz SDC-ID.
Check the Lightning site before attempting to change pills though...
jc.
Old Sep 8, 2002 | 01:25 AM
artguy's Avatar
im ordering the profec...still using the manual boost controller...was thinking i might need to go with larger hoses and needle valves possibly...or wait for the profec
j
Old Sep 8, 2002 | 09:39 AM
racer rx's Avatar
Hi Artguy,
You might want to check if there is a pill in your pre-control line and what size it is?
jc.
Old Sep 8, 2002 | 09:52 AM
Badog's Avatar
Re: boost question...what is the cause of pressure drop at transition on a seq setup??
Originally posted by artguy
hey all
j
Hey J
Do you have access to a datalogit? We did alot of testing on minimizing the down curve during the transition ( Nocab72 and I ) If you log, lets say, a 2000rpm->7000rpm pull in 3rd gear, that will give you a good idea on what is happening with the boost. Doing a 16-14-16 is not granular enough to tune the boost and minimize the drop.
Nocab got his transition down to less than .5 seconds by adjusting prespool settings (using a datalogit) and 1.5 turns out on the prespool actuator arm. I tuned the time down with the AVC-R.
If you can get a repeatable curve (get a couple of logs done) I can give you my spreadsheet and graph that will allow you to visualize the overall curve like below.
Old Sep 8, 2002 | 11:37 AM
artguy's Avatar
wow...nice chart! the datalogit is great isnt it?
Ill do some logs...Im thinking i may have to adjust the length of my actuator as well...actually tried that yesterday and thought it solved the problem...but no luck...
j
Old Sep 8, 2002 | 11:38 AM
artguy's Avatar
I took the pills out btw...I am using the manual boost controller to handle the flow now.
thanks for the input guys!!
any other ideas?
j
Old Sep 8, 2002 | 08:05 PM
racer rx's Avatar
Artguy wrote:I took the pills out btw...I am using the manual boost controller to handle the flow now.
But what is wired for the pre-control?
jc.
Old Sep 8, 2002 | 09:10 PM
artguy's Avatar
a needle valve is in place where the pill used to be I believe....Its been so long since i ran the stock setup that I cant remember if there was a pill in the precontrol line or not.
j
Queppa
Nov 18, 2024 03:47 AM
Skeese
65
Mar 28, 2017 03:30 PM
