Compressions different whats good for 89 TII
Old Sep 7, 2002 | 02:38 PM
goodspeed's Avatar
I figured I would do a compression check on my new engine 89 TII...it only has 800 miles on it.
I used a regular compression checker that you would use on a piston, so this might not of been 100% accurate.. and I couldn't get it screwed in super tight..
But I saw (according to the gauge (93 psi rear) (93psi front)
Both pefectly the same. I've seen people post numbers as high as 120psi, but Im assuming thats an n/a. And I know tII's have lower compression rotors, correct?
So is 93 psi on a 89 TII good?
Old Sep 7, 2002 | 02:50 PM
Scott 89t2's Avatar
SOLD THE RX-7!
wait till you have 2-3000 miles. it'll go up.
elfking
Aug 19, 2015 09:48 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
