Turbo II problem, HELP?????????????
Old Sep 5, 2002 | 01:53 PM
picazo505's Avatar
Well the other they i was driving around, and i gave her some gas ,and i check my boost ,and it was hitting 5psi,it didnt want to go no more, what the hell is wrong ,my normal psi boost is around 10, can some one help
Old Sep 5, 2002 | 02:03 PM
picazo505's Avatar
anybody????????????????
Old Sep 5, 2002 | 02:10 PM
Icemark's Avatar
Its because of the "basuka" tube
I think your gonna need to post a little more info on what the actual problem is... rather than you just have low boost. Low boost can be caused by:
a leak in the intake
bad timing
stuck throttle plate
faulty spark advance knock control
bad ACV
air filter clogged
bad waste gate
bad AFM
defective boost sensor
low compression
plugged/clogged cats
and countless oher issues.
Old Sep 5, 2002 | 04:02 PM
Fox4Life's Avatar
jimmyv13 had this same problem, he went through countless tests, replacing things. took him a couple months but he finnaly found out what it was. He had a leak in the line that went to the boost guage. Not very big. but just enough where it would rocket to 5 psi and just stop and stay there. take a look at that, couldnt hurt
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
Frisky Arab
13
Aug 18, 2015 05:30 PM
